Rspamd blocks all archives, also whitelisted senders
Hello
NethServer Version: 7.9
RSpamD: 3.0.
Nested archives and executable files blocking enabled.
I have whitelisted senders like dmarc_support@corp.mail.ru, noreply-dmarc-support@google.com, noreply@dmarc.yahoo.com to receive reports.
Recently RSpamD started blocking all emails with archive attachments. Updated RspamD to version 3.2, no result. Recreating the white list did not help.
Hi and welcome to NethServer Community,
I can confirm that attachments are blocked in any case, even if the sender is whitelisted.
If you add prefilter = true; to the FORBIDDEN_FILE_EXTENSION in /etc/rspamd/local.d/multimap.conf (line 135) and restart rspamd, whitelisted mail addresses/domains can send attachments but I don’t know if it conflicts with other settings/cases. /cc @stephdl
#reject email when the file extension is found
    FORBIDDEN_FILE_EXTENSION {
    type = "filename";
    filter = "extension";
    map = [
    "${CONFDIR}/forbidden_file_extension.map",
    prefilter = true;
    action = "reject";
    symbol = "FORBIDDEN_FILE_EXTENSION";
    description = "List of forbidden file extensions";
    message = "Forbidden attachment name extension";
no time yet, but thank, I will check it
I know this point is controversial, but the feature might behave like this by design:
Antivirus and antispam checks are skipped if an Allow rule matches – Email — NethServer 7 Final
That does not apply to attachment blocking, which can be intended as a company confidentiality policy in contrast to spam/virus countermeasures.
Maybe a custom template could help you to change this, indeed, if at a company level I decide to block archive or exe, if I allow a sender, I will accept his email with potential virus.
I think here we could use a conditional map rather a prefilter.
https://rspamd.com/doc/modules/multimap.html#conditional-maps
  require_symbols = "!IP_WHITELIST | !FROM_WHITELIST | !FROM_SUBDOMAINS_WHITELIST | !FROM_DOMAINS_WHITELIST";
    type = "filename";
    map = [
    action = "reject";
adding this seems to fix the issue
After internal discussion and because NS7 is at a feature freeze state…yes NS8 is coming :smiley:
We reach the point that we could not add a new feature that it could change the current behavior of more than 10K servers in the world.
Maybe in your case @Alik_Gusainov the best option for you is to make a custom template
[root@prometheus ~]# mkdir /etc/e-smith/templates-custom//etc/rspamd/local.d/multimap.conf
[root@prometheus ~]# cp /etc/e-smith/templates/etc/rspamd/local.d/multimap.conf/10base /etc/e-smith/templates-custom//etc/rspamd/local.d/multimap.conf
modify the line
vim /etc/e-smith/templates-custom//etc/rspamd/local.d/multimap.conf/10base
expand the custom template and restart services
[root@prometheus ~]# signal-event nethserver-mail-filter-save
