Just pushed a nethserver-mock
update to nethserver-testing
that groups together in a single %changelog
entry all git commits since the latest release. Check it out Dev Team (@giacomo, @davidep, @filippo_carletti, @alep, @stephdl, @Stll0, @alefattorini) , help is welcome!
https://github.com/NethServer/nethserver-mock/commit/17a01b973be42093f9c46bfbbeb98467324cbecf
http://packages.nethesis.it/nethserver/6.7/testing/x86_64/Packages/nethserver-mock-1.2.0-1.1.g17a01b9.ns6.noarch.rpm
The change affects only testing packages (those with g...
in release). This is an example output
$ rpm -qp --changelog nethserver-firewall-base-2.9.0-1.15.g2355f05.ns6.noarch.rpm * Thu Nov 26 2015 Davide Principi - 15.g2355f05.ns6 - FirewallRules UI: added fwrule-modify system validator. Refs #2809 (Davide Principi ) - Providers UI: check if provider is used by fw rules before delete. Refs #2809 (Davide Principi ) - FirewallRules UI: restyle rules (3). Refs #2809 (Davide Principi ) - Policy routing: ignore rules where dst is set to any. Refs #2809 (Giacomo Sanchietti ) ... - FirewallRules UI: select what kind of rules to show. Refs #2809 (Davide Principi ) - Rules UI: disable log checkbox if action is route. Refs #2809 (Davide Principi ) - Firewall rules UI: ROUTE action implementation for Policy routing. Refs #2809 (Davide Principi ) - Policy routing: move rules into fwrules db. Refs #2809 (Giacomo Sanchietti )
Perhaps author + email is too verbose…
