I have a roadwarrior VPN setup and am able to connect to my Nethserver network just fine. I’m able to access the local LAN and my internet IP is the WAN IP of my Nethserver.
However, I have an OpenVPN connection to a remote network, and I’m not able to access that network from the RWVPN connection. I tried adding a static route, but I’m not sure what gateway address to use. Does anyone have some pointers on how to route access to the remote network from RW?
We need to know more about your network diagram/setup and how you have configured your Roadwarrior VPN (Routed vs Bridged mode). Normally a static route is needed at the router level pointing to the internal green ip address of the Nethserver install assuming Nethserver isn’t the gateway/router of your network.
