Roundcube issues / connected to LDAP?
NethServer Version: 7RC1
Module: Roundcube / LDAP?
I experiment several difficulties with Roundcube:
  1. Filter/sieve (+) button and selecting existing filters and groups in the GUI is not working correctly. Is a matter of luck if something opens or not. In 80% of the cases nothing happens.
  2. The filter/sieve is not working in certain circumstances. The reason probably behind is probably the LDAP / login module, let me explain:
I’ve noticed that it is possible to login in the roundcube both as <user> and <user@server.name>. This creates under /var/lib/nethserver/vmail different folders!! The Email account is shared between the too. But the working filter/sieve rules are these from the directory <user@server.name> created by the respective login and not in/with the . It can be easily reproduced.
Roundcube must accept only one user style or if both <user> and <user@server.name> are acceptable login alternatives they must store all information in the same directory/roundcube account. Not sure what role is paling LDAP in this story. As far as I recall in the beta version I was able to login only with <user@server.name>. Nevertheless, WebTop accepts <user> as login as well and create the filter rule for Junk under /var/lib/nethserver/vmail/<user@server.name>.
from https://github.com/roundcube/roundcubemail/wiki/Configuration we can find
‘auto_create_user’
Sometimes hard to understand is the ‘auto_create_user’ property. So here’s a little background: Roundcube doesn’t actually manage users, that’s all the IMAP server’s job. But Roundcube keeps a reference to IMAP users in its local database in order to store settings, address books, spell check dictionaries and cached messages for a particular user. With this option enabled (that’s the default), a new Roundcube user reference is created once the IMAP login succeeds. If auto_create_user is set to False, the login only succeeds if there’s a matching user-record in the local Roundcube database. Even if a user enters the correct password and the IMAP login succeeds, the login will fail with the message “Login failed” until you manually create such a record in Roundcube’s database.
I worry that roundcube creates different users in its mysql database, user and user@domain.com are two different users for it. I have the same issue with tt-rss, you can login but you have two different users.
I have a workaround set in (of course in the template)
/etc/roundcubemail/defaults.inc.php
/etc/roundcubemail/config.inc.php
the value to your domain
$config['username_domain'] = 'domain.com';
After that you can login with toto or toto@domain.com
It works! Grazie Stephane!!
Is it something that actually should happen when the round cube get installed and the configuration happens?
I submitted a PR to correct this bug, it should come for everybody ASAP
I confirm. The managesieve server use the short format and creates the wrong maildir where to store sieve filter.
Both mail-server and roundcube packages needs a fix
https://github.com/NethServer/dev/issues/5151
https://github.com/NethServer/dev/issues/5150
The packages are ready for testing! /cc @quality_team @vedragan @stephdl @areguera @stef @transocean
To install them
yum --enablerepo=nethserver-testing update nethserver-roundcubemail nethserver-mail-server
Thank you Davide! I reverted the earlier work-arround and installed the packages. I can login correctly with or without domain. In the /var/lib/nethserver/vmail only directories with user@domain are created. The only small aspect that I’ve noticed is that now is not possible to login as root anymore (earlier it was). I don’t know if it really smart to do this at all :wink: In order to not have possible emails addressed to root lost, it is enough to create an email alias “root” to the preferred user…
I can login as “root” (no @domain suffix) with IMAP, but not from Roundcube:
Nov 16 09:55:20 vm7 dovecot: imap-login: Login: user=, method=PLAIN, rip=127.0.0.1, lip=127.0.0.1, mpid=2949, secured, session=
Nov 16 09:55:36 vm7 dovecot: imap(root): Connection closed in=0 out=381
Nov 16 09:59:46 vm7 dovecot: imap-login: Disconnected (auth failed, 1 attempts in 2 secs): user=, method=PLAIN, rip=127.0.0.1, lip=127.0.0.1, secured, session=
The new Roundcube configuration actually breaks the root login which is available only without @domain suffix.
@stephdl, @giacomo: do you think we can configure Roundcube to make an exception for root? Otherwise I could try to adjust the login name in the dovecot postlogin script…
I think it’s not possible.
Since the bug on sieve is resolved, I’d remove the username_domain option. Let’s give to the user the freedom to choose the preferred login.
New package in testing that allows root login /cc @vedragan
Now the user must choose the preferred login …from a dropdown menu, with a safe default :wink:
[root@NS7DEV3 ~]# rpm -qa nethserver-roundcubemail
nethserver-roundcubemail-1.2.4-1.3.g83cf3f6.ns7.noarch
[root@NS7DEV3 ~]# rpm -qa nethserver-mail-server
nethserver-mail-server-1.10.4-1.2.g5bff66e.ns7.noarch
the root user can login when you set the ‘local’ by the dropdown menu
the root@mydomain.com cannot login, but its is normal
I found two root folders after that
[root@NS7DEV3 ~]# ll /var/lib/nethserver/vmail/
total 4
drwx------ 3 vmail vmail 20 Nov 17 21:32 root
drwx------ 3 vmail vmail 20 Nov 17 21:30 root@stephdl.dyndns.org
-rw------- 1 vmail vmail 35 Nov 17 21:33 shared-mailboxes.db
drwx------ 4 vmail vmail 53 Nov 17 21:34 toto@stephdl.dyndns.org
drwx------ 3 vmail vmail 20 Nov 17 21:26 vmail
I don’t know if it is a side effect (we found also two root users in the mysql database of roundcubemail)
My concern is that it is not easy to know that you must choose ‘local’ to login with the root user. At least some doc should be done in the Admin manual.
When you use a user with the dropdown menu of your domain, whatever user@domain or user, are workable, only one user is created at
total 4
we can see that in mysql
MariaDB [roundcubemail]> SELECT * FROM users
| user_id | username                | mail_host | created             | last_login          | language | preferences                                                       |
|       1 | root                    | localhost | 2016-11-17 21:30:08 | 2016-11-17 21:30:08 | fr_FR    | a:1:{s:11:"client_hash";s:32:"c3a2e50f09a41581d9db4ada516a09c6";} |
|       2 | root                    | 127.0.0.1 | 2016-11-17 21:32:28 | 2016-11-17 21:32:28 | fr_FR    | a:1:{s:11:"client_hash";s:32:"dff655bc1073ab1d5ae392c238fcd307";} |
|       3 | toto@stephdl.dyndns.org | localhost | 2016-11-17 21:33:36 | 2016-11-17 21:39:07 | fr_FR    | a:1:{s:11:"client_hash";s:32:"c9f1cf9fba3ddf72be7368177390a3f1";} |
3 rows in set (0.00 sec)
I created a sieve rule to drop to the junk folder all email with a specific object, it is workable whater the user or user@domain form of login
4	/var/lib/nethserver/vmail/toto@stephdl.dyndns.org/Maildir/.Junk/cur/1479415098.M906084P16357.NS7DEV3.stephdl.dyndns.org,S=939,W=959:2,
4	/var/lib/nethserver/vmail/toto@stephdl.dyndns.org/Maildir/.Junk/cur/1479415174.M914169P16438.NS7DEV3.stephdl.dyndns.org,S=1000,W=1024:2,
Here the sieve script used
[root@NS7DEV3 ~]# cat /var/lib/nethserver/vmail/toto@stephdl.dyndns.org/.dovecot.sieve
require ["fileinto"];
# rule:[plop]
if header :contains "subject" "plop"
	fileinto "Junk";
Yes, confirmed. My suggestion/idea would be to:
  1. remove the drop-down from roundcube
  2. in the server GUI (Management->Email Adresses -> User mailboxes) configuration create a simple setting above all users for the root only with the only action possible redirection to
  3. use & extend the sieve script from Stephane to redirect all the root emails to the selected domain user and delete
I don’t know if (1) it is a good idea and also (2) how difficult is to implement. Feature freeze must be considered as well…
Me too! I could explain it, at least I can try…
Dovecot has multiple password DBs configured. One of them trims the user name domain suffix. And matches, if user is either root or root@domain.
Perhaps we can fix this.
IIRC this is already possible from the Profile page in server manager. The reason to have a root IMAP access is people do not set the forward address.
I must admit that I don’t know what you mean. On the page below I cannot see any root user…
root comes from /etc/passwd database and always exists; for this reason it has a special treatment in our configuration. I agree it should be displayed anyway…
Look at the upper-right corner:
In /etc/aliases:
[root@vm4 ~]# tail -3 /etc/aliases
# Person who should get root's mail
#root:		marc
root:		davide@example.com, roo
I tried again to reproduce this effect, without achieving it! On a development VM (don’t run on a production system):
# rm -_rf /var/lib/nethserver/vmail/*
# echo _'delete from users' | mysql roundcubemail
(safety check: remove the underscores)
Then
  • logged in as root Localhost ok
  • logged in as root Domain (fail, as exepected)
  • refuse wrong password in both cases
Only /var/lib/nethserver/vmail/root was created.
Could the other directory be created by an older package?
I will do again all steps this night, no problem davidep :wink:
In order to reproduce install nethserver-roundcubemail
yum install nethserver-roundcubemail
then login with the root user, you can find
[root@NS7DEV4 ~]# ll /var/lib/nethserver/vmail/
total 4
drwx------ 3 vmail vmail 20 Oct  6 19:35 root@stephdl.dyndns.org
-rw------- 1 vmail vmail 35 Oct  6 19:35 shared-mailboxes.db
drwx------ 3 vmail vmail 20 Oct  6 19:30 vmail
then update
after the installation or if you logout and login again with the root user you find
total 4
drwx------ 3 vmail vmail 20 Oct  6 19:36 root
-rw------- 1 vmail vmail 35 Oct  6 19:36 shared-mailboxes.db
I reproduced it many times, this is the content of /var/lib/nethserver/vmail/
/var/lib/nethserver/vmail/:
total 4
drwx------  5 vmail vmail 85 Oct  6 19:36 .
drwxr-xr-x. 8 root  root  95 Oct  6 19:28 ..
/var/lib/nethserver/vmail/root:
total 4
drwx------ 3 vmail vmail   20 Oct  6 19:36 .
drwx------ 5 vmail vmail   85 Oct  6 19:36 ..
drwx------ 9 vmail vmail 4096 Oct  6 19:37 Maildir
/var/lib/nethserver/vmail/root/Maildir:
total 24
drwx------ 9 vmail vmail 4096 Oct  6 19:37 .
drwx------ 3 vmail vmail   20 Oct  6 19:36 ..
drwx------ 2 vmail vmail    6 Oct  6 19:36 cur
-rw------- 1 vmail vmail    0 Oct  6 19:36 dovecot-acl-list
-rw------- 1 vmail vmail  272 Oct  6 19:37 dovecot.index.log
-rw------- 1 vmail vmail   96 Oct  6 19:37 dovecot.mailbox.log
-rw------- 1 vmail vmail   51 Oct  6 19:37 dovecot-uidlist
-rw------- 1 vmail vmail    8 Oct  6 19:37 dovecot-uidvalidity
-r--r--r-- 1 vmail vmail    0 Oct  6 19:36 dovecot-uidvalidity.57f68bbe
drwx------ 5 vmail vmail  102 Oct  6 19:37 .Drafts
drwx------ 5 vmail vmail  102 Oct  6 19:37 .Junk
-rw------- 1 vmail vmail    0 Oct  6 19:36 maildirfolder
drwx------ 2 vmail vmail    6 Oct  6 19:36 new
drwx------ 5 vmail vmail  102 Oct  6 19:37 .Sent
-rw------- 1 vmail vmail   23 Oct  6 19:37 subscriptions
drwx------ 2 vmail vmail    6 Oct  6 19:36 tmp
drwx------ 5 vmail vmail  102 Oct  6 19:37 .Trash
/var/lib/nethserver/vmail/root/Maildir/cur:
total 4
drwx------ 2 vmail vmail    6 Oct  6 19:36 .
drwx------ 9 vmail vmail 4096 Oct  6 19:37 ..
/var/lib/nethserver/vmail/root/Maildir/.Drafts:
total 12
drwx------ 2 vmail vmail    6 Oct  6 19:37 cur
-rw------- 1 vmail vmail  168 Oct  6 19:37 dovecot.index.log
-rw------- 1 vmail vmail    0 Oct  6 19:37 maildirfolder
drwx------ 2 vmail vmail    6 Oct  6 19:37 new
drwx------ 2 vmail vmail    6 Oct  6 19:37 tmp
/var/lib/nethserver/vmail/root/Maildir/.Drafts/cur:
total 0
drwx------ 2 vmail vmail   6 Oct  6 19:37 .
drwx------ 5 vmail vmail 102 Oct  6 19:37 ..
/var/lib/nethserver/vmail/root/Maildir/.Drafts/new:
total 0
/var/lib/nethserver/vmail/root/Maildir/.Drafts/tmp:
total 0
/var/lib/nethserver/vmail/root/Maildir/.Junk:
total 12
/var/lib/nethserver/vmail/root/Maildir/.Junk/cur:
total 0
/var/lib/nethserver/vmail/root/Maildir/.Junk/new:
total 0
/var/lib/nethserver/vmail/root/Maildir/.Junk/tmp:
total 0
/var/lib/nethserver/vmail/root/Maildir/new:
total 4
/var/lib/nethserver/vmail/root/Maildir/.Sent:
total 12
/var/lib/nethserver/vmail/root/Maildir/.Sent/cur:
total 0
/var/lib/nethserver/vmail/root/Maildir/.Sent/new:
total 0
/var/lib/nethserver/vmail/root/Maildir/.Sent/tmp:
total 0
/var/lib/nethserver/vmail/root/Maildir/tmp:
total 4
/var/lib/nethserver/vmail/root/Maildir/.Trash:
total 12
/var/lib/nethserver/vmail/root/Maildir/.Trash/cur:
total 0
/var/lib/nethserver/vmail/root/Maildir/.Trash/new:
total 0
/var/lib/nethserver/vmail/root/Maildir/.Trash/tmp:
total 0
/var/lib/nethserver/vmail/root@stephdl.dyndns.org:
total 4
drwx------ 3 vmail vmail   20 Oct  6 19:35 .
drwx------ 9 vmail vmail 4096 Oct  6 19:35 Maildir
/var/lib/nethserver/vmail/root@stephdl.dyndns.org/Maildir:
total 24
drwx------ 9 vmail vmail 4096 Oct  6 19:35 .
drwx------ 3 vmail vmail   20 Oct  6 19:35 ..
drwx------ 2 vmail vmail    6 Oct  6 19:35 cur
-rw------- 1 vmail vmail    0 Oct  6 19:35 dovecot-acl-list
-rw------- 1 vmail vmail  168 Oct  6 19:35 dovecot.index.log
-rw------- 1 vmail vmail   96 Oct  6 19:35 dovecot.mailbox.log
-rw------- 1 vmail vmail   51 Oct  6 19:35 dovecot-uidlist
-rw------- 1 vmail vmail    8 Oct  6 19:35 dovecot-uidvalidity
-r--r--r-- 1 vmail vmail    0 Oct  6 19:35 dovecot-uidvalidity.57f68b7d
drwx------ 5 vmail vmail  102 Oct  6 19:35 .Drafts
drwx------ 5 vmail vmail  102 Oct  6 19:35 .Junk
-rw------- 1 vmail vmail    0 Oct  6 19:35 maildirfolder
drwx------ 2 vmail vmail    6 Oct  6 19:35 new
drwx------ 5 vmail vmail  102 Oct  6 19:35 .Sent
-rw------- 1 vmail vmail   23 Oct  6 19:35 subscriptions
drwx------ 2 vmail vmail    6 Oct  6 19:35 tmp
drwx------ 5 vmail vmail  102 Oct  6 19:35 .Trash
/var/lib/nethserver/vmail/root@stephdl.dyndns.org/Maildir/cur:
total 4
drwx------ 2 vmail vmail    6 Oct  6 19:35 .
drwx------ 9 vmail vmail 4096 Oct  6 19:35 ..
/var/lib/nethserver/vmail/root@stephdl.dyndns.org/Maildir/.Drafts:
total 12
/var/lib/nethserver/vmail/root@stephdl.dyndns.org/Maildir/.Drafts/cur:
total 0
drwx------ 5 vmail vmail 102 Oct  6 19:35 ..
/var/lib/nethserver/vmail/root@stephdl.dyndns.org/Maildir/.Drafts/new:
total 0
/var/lib/nethserver/vmail/root@stephdl.dyndns.org/Maildir/.Drafts/tmp:
total 0
/var/lib/nethserver/vmail/root@stephdl.dyndns.org/Maildir/.Junk:
total 12
/var/lib/nethserver/vmail/root@stephdl.dyndns.org/Maildir/.Junk/cur:
total 0
/var/lib/nethserver/vmail/root@stephdl.dyndns.org/Maildir/.Junk/new:
total 0
/var/lib/nethserver/vmail/root@stephdl.dyndns.org/Maildir/.Junk/tmp:
total 0
/var/lib/nethserver/vmail/root@stephdl.dyndns.org/Maildir/new:
total 4
/var/lib/nethserver/vmail/root@stephdl.dyndns.org/Maildir/.Sent:
total 12
/var/lib/nethserver/vmail/root@stephdl.dyndns.org/Maildir/.Sent/cur:
total 0
/var/lib/nethserver/vmail/root@stephdl.dyndns.org/Maildir/.Sent/new:
total 0
/var/lib/nethserver/vmail/root@stephdl.dyndns.org/Maildir/.Sent/tmp:
total 0
/var/lib/nethserver/vmail/root@stephdl.dyndns.org/Maildir/tmp:
total 4
/var/lib/nethserver/vmail/root@stephdl.dyndns.org/Maildir/.Trash:
total 12
/var/lib/nethserver/vmail/root@stephdl.dyndns.org/Maildir/.Trash/cur:
total 0
/var/lib/nethserver/vmail/root@stephdl.dyndns.org/Maildir/.Trash/new:
total 0
/var/lib/nethserver/vmail/root@stephdl.dyndns.org/Maildir/.Trash/tmp:
total 0
/var/lib/nethserver/vmail/vmail:
total 0
drwx------ 3 vmail vmail  20 Oct  6 19:30 .
drwx------ 5 vmail vmail 121 Oct  6 19:30 Maildir
/var/lib/nethserver/vmail/vmail/Maildir:
total 12
drwx------ 5 vmail vmail 121 Oct  6 19:30 .
drwx------ 3 vmail vmail  20 Oct  6 19:30 ..
drwx------ 2 vmail vmail   6 Oct  6 19:30 cur
-rw------- 1 vmail vmail  16 Oct  6 19:30 dovecot-acl
-rw------- 1 vmail vmail  17 Oct  6 19:30 dovecot-acl-list
-rw------- 1 vmail vmail 104 Oct  6 19:30 dovecot.index.log
-rw------- 1 vmail vmail   0 Oct  6 19:30 maildirfolder
drwx------ 2 vmail vmail   6 Oct  6 19:30 new
drwx------ 2 vmail vmail   6 Oct  6 19:30 tmp
/var/lib/nethserver/vmail/vmail/Maildir/cur:
total 0
drwx------ 2 vmail vmail   6 Oct  6 19:30 .
drwx------ 5 vmail vmail 121 Oct  6 19:30 ..
/var/lib/nethserver/vmail/vmail/Maildir/new:
total 0
/var/lib/nethserver/vmail/vmail/Maildir/tmp:
total 0
