Right command to remove Zammad incl. Elasticsearch from the system
NethServer Version: 7.9.2009
Module: Zammad
Hello friends,
i installed Zammad and Elasticsearch on my Nethserver and I want to uninstall it again. I think that “yum remove nethserver-zammad” is not enough to get Zammad incl. Elasticsearch off the system again. What commands are needed to remove Zammad and Elasticsearch completely from the system?
Regards…
Uwe
You may use
yum autoremove nethserver-zammad
but please check carefully what’s going to be removed.
But this removed only Zammad. ElasticSearch is on the system like before.
Is elasticsearch used by another application?
You may remove it manually:
yum remove elasticsearch
