I have a NS as a frontend firewall and accepting mydomain.de in the Webserver.
Now I want have ns2.mydomain.de point to a secondary internal NS server with IP 192.168.42.20 which hosts a webtop instance and owncloud but I am not successful.
The reason is, that I want to have several application Nethservers for different subdomains and I want to separate firewall from applications servers.
Are you using reverse-proxy with path or with domain?
Makes a BIG difference…
Additionally, using SSL almost needs a LetsEncrypt Cert on the target server, a self created one will give you issues.
The frontend NethServer could handle SSL for almost all stuff (forwarding only http), but AFAIK this will not work for Nextcloud, SoGo or Webtop, as these use certain technologies like Restful which doesn’t work well with reverse proxies.
For Nextcloud at least this is needed:
Needs to be set in the newer Cockpit, under Applications → Nextcloud → Settings
Trusted domains (one per line),
Untrusted domain in NextCloud
Adding n2.mydomain.de to the second NS nextcloud configuration as trusted domain solves the nextcloud problem in cases 1 und 3. What I dont’ understand is, that the check box "Use virtual host for nextcloud is NOT checked. The explination under “trusted domains” says, that if this check box un unchecked nextcloud is reachable from all IPs and FQNs. I am for example able to access nextcloud with a local IP.
path or domain.
It is not possible to use a subdomain in the path-syntax (like https://ns2.mydomain.de), so I must use domain (ns2.mydomain.de)
However then I tried with Path /ns2 -> https://192.168.42.20 it works neither (cannot display page).
I found the reason for problem 1 myself: The problem is, that the /etc/httpd/conf.d/ already contained three reverse proxy files for webtop although webtop is NOT installied on this machine. These make it impossible to reverse proxy an domain contaning /webtop in the path. Removing this files solved the problem (temporarily).
The files are webtop5-webdav.conf, webtop5-zpush.conf, webtop.conf.
I think either these files should only be installied/aktivated, when webtop gets installed. In addition the configured reverse proxy domains should take precedence over other configuration especially those with ProxyPass.
The question is now: How to disable it without having the next update break the configuration.
In the destination server I had to comment out the redirection from http to https in file conf.d/default-virtualhost.inc because the SSL is done by the front reverse proxy server.
@Andy_Wismer Thanks a lot.
It would be nice, if the disabling of SSL enforcement would be available in the UI in the future. Perhaps someone wil do it.
I found a simpler solution. Just proxy to https instead of http (which is not working currently). This removes the need to change existing templates. However, the files webtop5-webdav.conf, webtop5-zpush.conf, webtop.conf still have to be removed, because the take precedence over the reverse proxy configuration.
Also I improved the reverse proxy to handle WebSockets automatically.
Indeed, this is the output of the command:
webtop5-zpush-1.2.1-1.ns7.noarch
webtop5-webdav-0.3.0-1.ns7.noarch
webtop5-1.4.7-1.ns7.noarch
I checked at another NS which has webtop5 installed. The output there is:
nethserver-webtop5-1.6.3-1.ns7.noarch
So removing webtop5 from with the “Remove” command from the applications dashboard does a partial uninstall only. Could this be improved so that NS deinstalls all packages of an application when it gets removed?
Morover templates are not removed when the nethserver-xxxx is removed, that could hurt badly I think.
The easy way could use a %postun in the rpm and clean up all templates, but I think no developers have made it…at least I have never read something related to templates removal in a rpm spec.
The httpd case is specific because httpd is always running, not like another services that we could uninstall or stop. Maybe we have a room for improvements here
I don’t suggest to automatically remove templates or settings during package removal?
Now modules can be uninstalled… why don’t realize two toggles (one for settings, one for custom templates?)
What about “yum autoremove”. In theory this should remove all packages which where installed only because of a dependency of others, but are not longer referenced.
I just issued the command in one of my server and it suggests quite many packages for removal. Do you think it is save to say “Yes”? to them? If yum autoremove is save, then it should be considered to issue this command at package removal. This should also remove templates.
Removing:
fann x86_64 2.2.0-6.el7 @epel 349 k
ghostscript x86_64 9.25-2.el7_7.3 @ce-updates 150 k
ghostscript-fonts noarch 5.50-32.el7 @ce-base 622 k
nethserver-rh-php71-php-fpm noarch 1.1.2-1.ns7 @nethserver-updates 206
openblas-serial x86_64 0.3.3-2.el7 @epel 35 M
php-imap x86_64 5.4.16-9.el7 @epel 105 k
php-ldap x86_64 5.4.16-48.el7 @ce-base 57 k
php-mbstring x86_64 5.4.16-48.el7 @ce-base 1.3 M
php-mcrypt x86_64 5.4.16-9.el7 @epel 48 k
php-process x86_64 5.4.16-48.el7 @ce-base 78 k
poppler-data noarch 0.4.6-3.el7 @ce-base 11 M
python2-gflags noarch 2.0-5.el7 @epel 328 k
sclo-php71-php-imap x86_64 7.1.30-1.el7 @ce-sclo-sclo 100 k
sclo-php71-php-mcrypt x86_64 7.1.30-1.el7 @ce-sclo-sclo 47 k
sclo-php71-php-smbclient x86_64 1.0.0-1.el7 @ce-sclo-sclo 98 k
sclo-php71-php-tidy x86_64 7.1.30-1.el7 @ce-sclo-sclo 415 k
sclo-php72-php-pecl-imagick x86_64 3.4.4-3.el7 @ce-sclo-sclo 506 k
sclo-php72-php-smbclient x86_64 1.0.0-1.el7 @ce-sclo-sclo 98 k
Removing for dependencies:
libgfortran x86_64 4.8.5-39.el7 @ce-base 1.1 M
libmcrypt x86_64 2.5.8-13.el7 @epel 283 k
libquadmath x86_64 4.8.5-39.el7 @ce-base 276 k
rh-php71 x86_64 1-1.el7 @ce-sclo-rh 0.0
rh-php71-php-bcmath x86_64 7.1.30-2.el7 @ce-sclo-rh 58 k
rh-php71-php-cli x86_64 7.1.30-2.el7 @ce-sclo-rh 8.4 M
rh-php71-php-common x86_64 7.1.30-2.el7 @ce-sclo-rh 4.5 M
rh-php71-php-enchant x86_64 7.1.30-2.el7 @ce-sclo-rh 25 k
rh-php71-php-fpm x86_64 7.1.30-2.el7 @ce-sclo-rh 4.3 M
rh-php71-php-gd x86_64 7.1.30-2.el7 @ce-sclo-rh 375 k
rh-php71-php-intl x86_64 7.1.30-2.el7 @ce-sclo-rh 465 k
rh-php71-php-json x86_64 7.1.30-2.el7 @ce-sclo-rh 40 k
rh-php71-php-ldap x86_64 7.1.30-2.el7 @ce-sclo-rh 65 k
rh-php71-php-mbstring x86_64 7.1.30-2.el7 @ce-sclo-rh 1.4 M
rh-php71-php-mysqlnd x86_64 7.1.30-2.el7 @ce-sclo-rh 419 k
rh-php71-php-opcache x86_64 7.1.30-2.el7 @ce-sclo-rh 395 k
rh-php71-php-pdo x86_64 7.1.30-2.el7 @ce-sclo-rh 189 k
rh-php71-php-pear noarch 1:1.10.4-1.el7 @ce-sclo-rh 2.1 M
rh-php71-php-pecl-apcu x86_64 5.1.8-1.el7 @ce-sclo-rh 177 k
rh-php71-php-pgsql x86_64 7.1.30-2.el7 @ce-sclo-rh 183 k
rh-php71-php-process x86_64 7.1.30-2.el7 @ce-sclo-rh 90 k
rh-php71-php-soap x86_64 7.1.30-2.el7 @ce-sclo-rh 308 k
rh-php71-php-xml x86_64 7.1.30-2.el7 @ce-sclo-rh 427 k
rh-php71-php-zip x86_64 7.1.30-2.el7 @ce-sclo-rh 136 k
rh-php71-runtime x86_64 1-1.el7 @ce-sclo-rh 22 k
At another server the list was only one package:
python2-gflags-2.0-5.el7.noarch
In theory yes, rh-php71 has been removed as dependencies from another rpm, probably nextcloud IIRC
No, you cannot mix dependencies removal which come from yum and templates removal that it comes from esmith::templates.
The answer cannot be simple, either each developers takes care to remove template of httpd, or we provide a way to remove all templates, but in any ways, all rpm must be analysed and provide a way to remove all its templates.
As I said, it concerns only httpd, because in most of all cases the service is stopped after you remove the nethserver-xxxx rpm
