hi all i did a fresh install of nethserver 7.8 and i have a configuration backup from 7.7 but when i try to restore it just stuck with S20nethserver-base-restore-yumrepos even when i dont want it to reinstall packages
any idea how to solve this?
if there is also a workaround to restore at least the firewall and network settings and ldap user configuration i will appreciate that.
could i use the files in the tar restore files to manually restore settings and if so how i should proceed
