Restore a directory with many files inside
NethServer Version: 7.9.2009
Module: Data-Backup/Restore
Hello everbody,
when I try to rerstore data from my backup, I receive this warning and have not found a way to overcome the problem. In this case I try to restore a Wordpress backup, which does have more than 500 files inside the vhost. Not possible per design?
Switch to Advanced mode and use doxeon_net$ (with a trailing $ sign).
It should return one result, choose that and restore.
thanks @filippo_carletti this did the trick!
