Is there any method (maybe throught shell ?) to reset user home folder permissions as done for shared folders on gui ?
Actually I’m trying to migrate our company old samba server to a new one with NS7…but when I rsync “old” home directories to new ones, with rsync -a /source /dest, rsync keeps original (old server) owner & group membership.
On the other hand, without the -a flag, rsync set owner and group to root:root and also this is not correct in my scenario.
I would like something to reset home folder permission (and its contents) for a particular user. Otherwise I need everytime to do something like :
find . -type d -exec chmod 770 {} +
find . -type f -exec chmod 660 {} +
and then issue a “chown -R new_user@XXXXXX:domain users@XXXXXX” against new home folder.
To give new files the destination-default permissions (while leaving existing files unchanged), make sure that the --perms option is off and use --chmod=ugo=rwX (which ensures that all non-masked bits get enabled).
It seems to me the only way to achive what I want. Unfortunately on rsync you can only set chmod permissions to whatever but no (destination) owner and group…thank you so much again
Unfortunately this version (it’s quite old) lacks some interesting features like : quick chmodding with bitmask like chmod=D770,F660 or chowning target files like chown=user:group (this is the quick way and syntax to map local to remote user/group).
