Reset 2FA for Cluster admin page
Module: cluster-admin
Hi team,
I have lost access to my 2FA for the cluster-admin page.
How can I reset this ?
Kind regards, Klaas-Jan
https://docs.nethserver.org/projects/ns8/en/latest/cluster.html#reset-the-cluster-administrator-password
Reset the cluster administrator password
If you are locked out of the web user interface and you can still access a system command-line shell as root (e.g. by the system recovery console or SSH), run the following command to disable 2FA and reset the password:
api-cli run alter-user --data '{"user":"admin","set":{"password":"Nethesis,1234","2fa":false}}'
Replace the admin and Nethesis,1234 default credentials as needed.
Hi dnutan,
Thanks, completely overlooked that one in the documentation :slight_smile:
