Hello my friends,
i need a explanation.
I would like to test reverse proxy module in nethserver.
reading the nethserver documentation:
https://docs.nethserver.org/en/v7/proxy_pass.html#proxy-pass-section
is necessary that nethserver where is installed reverse proxy is the firewall/gateway of the lan??
Thanks
You can redirect port 80 and 443 with a port forwarding to an internal server and then use it as reverse proxy. I think there isn’t any problem.
ok thanks for you feedback.
i need some other test for a working configuration.
Thanks
I have a working configuration with a reverse proxy on an internal server. Have you already tried to configure it?
Hi Luca_Menghetti,
I have MediaWiki installed on a LOCAL server (toto-dev.com). MediaWiki is installed as a vhost in the directory /var/lib/nethserver/vhost/mediawiki.
I use Reverse Proxy module on the LOCAL server (toto-dev.com) to redirect acces to mediawiki.toto-dev.com.
All is working fine.
Michel-Adré
I have configured reverse proxy, but I have problems to access in some case. In the next days I investigate about this. Thanks
