mrmarkuz
(Markus Neuberger)
#1
do you have problems installing/updating too, I tried different mirrors and neth repos.
Maybe wrong repomd.xml?
https://mirror.nethesis.it/nethserver/7.7.1908/nethforge/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml signature could not be verified for *
Workaround:
yum --nogpg update
dnutan
(Marc)
#2
Cannot test right now but maybe it is related to
davidep
(Davide Principi)
#3
I fixed the signature in the master mirror. Should be fixed in a few hours…
davidep
(Davide Principi)
#4
I’m sorry it was my mistake. A similar issue was affecting other repositories too. It should be fixed now.
Thanks to @mrmarkuz @dnutan @alep for pointing it out.
mrmarkuz
(Markus Neuberger)
#5
No problem, these things just happen. Thanks for the quick fix.
