Renaming cn ldap attribute
Hi all, I’ve discovered that renaming a PC joined to the domain is not a good idea: the CN ldap attribute doesn’t change. Now I have this issue:
dn: CN=01ORGCED0322,CN=Computers,DC=ad,DC=csaricerche,DC=com
cn: 01ORGCED0322
sAMAccountName: CENTR0322$
dNSHostName: CENTR0322.csaricerche.com
There is a way to change the CN attribute of a joined PC?
So there is no way to change the CN of a computer ldap entry? IIRC that’s not the same behaviour in NS7…
Paolo
As you can see, CN is part of the entry DN, it’s not like other attributes. Changing CN requires generating a new LDAP entry. Why do you want to change CN?
I’d suggest to
  • Remove the PC from the domain, delete the PC account CENTR0322$
  • Fix the PC name
  • Add the PC again to the domain
You are right, the problem is that I have renamed a joined pc and I have discovered that cn in ldap still contains the old name.
So to rename a pc I have to remove from the domain then rename and re-join? Why directly renaming the joined pc doesn’t rename even the cn ldap attribute? AFAIK AD behaves differently isn’t it?
I don’t know. It’s better to ask Samba experts in the Samba users mailing-list. AFAIK CN cannot be changed as easily as other attributes since it’s part of the DN: it’s how LDAP works. The LDAP modrdn operation would be required in this case, but active directory may have its additional rules.
Second suggestion: if you can live with it, do not touch it.
