Hello world!
When I install the Firewall package through the software center and then remove it through Applications this causes alot of errors in /var/log/messages :
[root@proxy ~]# tail -f /var/log/messages | grep -i 'failed\|error\|warning\|unable'
Mar 16 06:30:36 proxy esmith::event[4580]: WARNING in /etc/e-smith/db/configuration/migrate//MigrateAmavisdPropertyToRspamd_Issue5394.ns7: value() should not be used on records with properties, use prop() at /usr/share/perl5/vendor_perl/esmith/ConfigDB/Record.pm line 86.
Mar 16 06:30:36 proxy esmith::event[4580]: WARNING: Template processing succeeded for /: 1 fragment generated warnings
Mar 16 06:30:36 proxy systemd: [/usr/lib/systemd/system/netdata.service:56] Failed to parse capability in bounding/ambient set, ignoring: CAP_PERFMON
Mar 16 06:30:37 proxy esmith::event[4696]: WARNING in /etc/e-smith/db/configuration/migrate//MigrateAmavisdPropertyToRspamd_Issue5394.ns7: value() should not be used on records with properties, use prop() at /usr/share/perl5/vendor_perl/esmith/ConfigDB/Record.pm line 86.
Mar 16 06:30:37 proxy esmith::event[4696]: WARNING: Template processing succeeded for /: 1 fragment generated warnings
Mar 16 06:30:38 proxy esmith::event[4993]: WARNING in /etc/e-smith/db/configuration/migrate//MigrateAmavisdPropertyToRspamd_Issue5394.ns7: value() should not be used on records with properties, use prop() at /usr/share/perl5/vendor_perl/esmith/ConfigDB/Record.pm line 86.
Mar 16 06:30:38 proxy esmith::event[4993]: WARNING: Template processing succeeded for /: 1 fragment generated warnings
Mar 16 06:30:38 proxy systemd: [/usr/lib/systemd/system/netdata.service:56] Failed to parse capability in bounding/ambient set, ignoring: CAP_PERFMON
Mar 16 06:30:38 proxy esmith::event[5024]: WARNING in /etc/e-smith/db/configuration/migrate//MigrateAmavisdPropertyToRspamd_Issue5394.ns7: value() should not be used on records with properties, use prop() at /usr/share/perl5/vendor_perl/esmith/ConfigDB/Record.pm line 86.
Mar 16 06:30:38 proxy esmith::event[5024]: WARNING: Template processing succeeded for /: 1 fragment generated warnings
Mar 16 06:30:39 proxy esmith::event[5338]: WARNING in /etc/e-smith/db/configuration/migrate//MigrateAmavisdPropertyToRspamd_Issue5394.ns7: value() should not be used on records with properties, use prop() at /usr/share/perl5/vendor_perl/esmith/ConfigDB/Record.pm line 86.
Mar 16 06:30:39 proxy esmith::event[5338]: WARNING: Template processing succeeded for /: 1 fragment generated warnings
Mar 16 06:30:40 proxy systemd: [/usr/lib/systemd/system/netdata.service:56] Failed to parse capability in bounding/ambient set, ignoring: CAP_PERFMON
Mar 16 06:30:41 proxy esmith::event[5839]: WARNING in /etc/e-smith/db/configuration/migrate//MigrateAmavisdPropertyToRspamd_Issue5394.ns7: value() should not be used on records with properties, use prop() at /usr/share/perl5/vendor_perl/esmith/ConfigDB/Record.pm line 86.
Mar 16 06:30:41 proxy esmith::event[5839]: WARNING: Template processing succeeded for /: 1 fragment generated warnings
Mar 16 06:30:42 proxy systemd: [/usr/lib/systemd/system/netdata.service:56] Failed to parse capability in bounding/ambient set, ignoring: CAP_PERFMON
Mar 16 06:30:42 proxy smartd[5873]: Sending warning via /usr/libexec/smartmontools/smartdnotify to root ...
Mar 16 06:30:42 proxy smartd[5873]: Warning via /usr/libexec/smartmontools/smartdnotify to root: successful
Mar 16 06:30:42 proxy esmith::event[6251]: WARNING in /etc/e-smith/db/configuration/migrate//MigrateAmavisdPropertyToRspamd_Issue5394.ns7: value() should not be used on records with properties, use prop() at /usr/share/perl5/vendor_perl/esmith/ConfigDB/Record.pm line 86.
Mar 16 06:30:42 proxy esmith::event[6251]: WARNING: Template processing succeeded for /: 1 fragment generated warnings
Mar 16 06:30:43 proxy systemd: [/usr/lib/systemd/system/netdata.service:56] Failed to parse capability in bounding/ambient set, ignoring: CAP_PERFMON
Mar 16 06:30:45 proxy esmith::event[6660]: WARNING in /etc/e-smith/db/configuration/migrate//MigrateAmavisdPropertyToRspamd_Issue5394.ns7: value() should not be used on records with properties, use prop() at /usr/share/perl5/vendor_perl/esmith/ConfigDB/Record.pm line 86.
Mar 16 06:30:45 proxy esmith::event[6660]: WARNING: Template processing succeeded for /: 1 fragment generated warnings
Mar 16 06:30:45 proxy systemd: [/usr/lib/systemd/system/netdata.service:56] Failed to parse capability in bounding/ambient set, ignoring: CAP_PERFMON
Mar 16 06:30:46 proxy esmith::event[7064]: WARNING in /etc/e-smith/db/configuration/migrate//MigrateAmavisdPropertyToRspamd_Issue5394.ns7: value() should not be used on records with properties, use prop() at /usr/share/perl5/vendor_perl/esmith/ConfigDB/Record.pm line 86.
Mar 16 06:30:46 proxy esmith::event[7064]: WARNING: Template processing succeeded for /: 1 fragment generated warnings
Mar 16 06:30:46 proxy systemd: [/usr/lib/systemd/system/netdata.service:56] Failed to parse capability in bounding/ambient set, ignoring: CAP_PERFMON
Mar 16 06:30:46 proxy esmith::event[7189]: WARNING in /etc/e-smith/db/configuration/migrate//MigrateAmavisdPropertyToRspamd_Issue5394.ns7: value() should not be used on records with properties, use prop() at /usr/share/perl5/vendor_perl/esmith/ConfigDB/Record.pm line 86.
Mar 16 06:30:46 proxy esmith::event[7189]: WARNING: Template processing succeeded for /: 1 fragment generated warnings
Mar 16 06:30:47 proxy systemd: [/usr/lib/systemd/system/netdata.service:56] Failed to parse capability in bounding/ambient set, ignoring: CAP_PERFMON
Mar 16 06:30:47 proxy esmith::event[7559]: WARNING in /etc/e-smith/db/configuration/migrate//MigrateAmavisdPropertyToRspamd_Issue5394.ns7: value() should not be used on records with properties, use prop() at /usr/share/perl5/vendor_perl/esmith/ConfigDB/Record.pm line 86.
Mar 16 06:30:47 proxy esmith::event[7559]: WARNING: Template processing succeeded for /: 1 fragment generated warnings
Mar 16 06:30:48 proxy systemd: [/usr/lib/systemd/system/netdata.service:56] Failed to parse capability in bounding/ambient set, ignoring: CAP_PERFMON
Mar 16 06:30:49 proxy esmith::event[8494]: WARNING in /etc/e-smith/db/configuration/migrate//MigrateAmavisdPropertyToRspamd_Issue5394.ns7: value() should not be used on records with properties, use prop() at /usr/share/perl5/vendor_perl/esmith/ConfigDB/Record.pm line 86.
Mar 16 06:30:49 proxy esmith::event[8494]: WARNING: Template processing succeeded for /: 1 fragment generated warnings
Mar 16 06:30:49 proxy systemd: [/usr/lib/systemd/system/netdata.service:56] Failed to parse capability in bounding/ambient set, ignoring: CAP_PERFMON
Mar 16 06:30:50 proxy esmith::event[9075]: WARNING in /etc/e-smith/db/configuration/migrate//MigrateAmavisdPropertyToRspamd_Issue5394.ns7: value() should not be used on records with properties, use prop() at /usr/share/perl5/vendor_perl/esmith/ConfigDB/Record.pm line 86.
Mar 16 06:30:50 proxy esmith::event[9075]: WARNING: Template processing succeeded for /: 1 fragment generated warnings
Mar 16 06:30:50 proxy systemd: [/usr/lib/systemd/system/netdata.service:56] Failed to parse capability in bounding/ambient set, ignoring: CAP_PERFMON
Mar 16 06:30:50 proxy unbound-checkconf: unbound-checkconf: no errors in /etc/unbound/unbound.conf
Mar 16 06:30:51 proxy esmith::event[10013]: WARNING in /etc/e-smith/db/configuration/migrate//MigrateAmavisdPropertyToRspamd_Issue5394.ns7: value() should not be used on records with properties, use prop() at /usr/share/perl5/vendor_perl/esmith/ConfigDB/Record.pm line 86.
Mar 16 06:30:51 proxy esmith::event[10013]: WARNING: Template processing succeeded for /: 1 fragment generated warnings
Mar 16 06:30:51 proxy esmith::event[10025]: WARNING in /etc/e-smith/db/configuration/migrate//MigrateAmavisdPropertyToRspamd_Issue5394.ns7: value() should not be used on records with properties, use prop() at /usr/share/perl5/vendor_perl/esmith/ConfigDB/Record.pm line 86.
Mar 16 06:30:51 proxy esmith::event[10025]: WARNING: Template processing succeeded for /: 1 fragment generated warnings
Mar 16 06:31:13 proxy esmith::event[10066]: WARNING in /etc/e-smith/db/configuration/migrate//MigrateAmavisdPropertyToRspamd_Issue5394.ns7: value() should not be used on records with properties, use prop() at /usr/share/perl5/vendor_perl/esmith/ConfigDB/Record.pm line 86.
Mar 16 06:31:13 proxy esmith::event[10066]: WARNING: Template processing succeeded for /: 1 fragment generated warnings
Mar 16 06:31:13 proxy esmith::event[10069]: WARNING in /etc/e-smith/db/configuration/migrate//MigrateAmavisdPropertyToRspamd_Issue5394.ns7: value() should not be used on records with properties, use prop() at /usr/share/perl5/vendor_perl/esmith/ConfigDB/Record.pm line 86.
Mar 16 06:31:13 proxy esmith::event[10069]: WARNING: Template processing succeeded for /: 1 fragment generated warnings
Mar 16 06:31:14 proxy systemd: [/usr/lib/systemd/system/netdata.service:56] Failed to parse capability in bounding/ambient set, ignoring: CAP_PERFMON
Mar 16 06:31:14 proxy esmith::event[10194]: WARNING in /etc/e-smith/db/configuration/migrate//MigrateAmavisdPropertyToRspamd_Issue5394.ns7: value() should not be used on records with properties, use prop() at /usr/share/perl5/vendor_perl/esmith/ConfigDB/Record.pm line 86.
Mar 16 06:31:14 proxy esmith::event[10194]: WARNING: Template processing succeeded for /: 1 fragment generated warnings
Mar 16 06:31:15 proxy esmith::event[10497]: WARNING in /etc/e-smith/db/configuration/migrate//MigrateAmavisdPropertyToRspamd_Issue5394.ns7: value() should not be used on records with properties, use prop() at /usr/share/perl5/vendor_perl/esmith/ConfigDB/Record.pm line 86.
Mar 16 06:31:15 proxy esmith::event[10497]: WARNING: Template processing succeeded for /: 1 fragment generated warnings
Mar 16 06:31:15 proxy esmith::event[10839]: WARNING in /etc/e-smith/db/configuration/migrate//MigrateAmavisdPropertyToRspamd_Issue5394.ns7: value() should not be used on records with properties, use prop() at /usr/share/perl5/vendor_perl/esmith/ConfigDB/Record.pm line 86.
Mar 16 06:31:15 proxy esmith::event[10839]: WARNING: Template processing succeeded for /: 1 fragment generated warnings
Mar 16 06:31:16 proxy esmith::event[10863]: Action: /etc/e-smith/events/static-routes-save/S25interface-config-write FAILED: 2 [0.055705]
Mar 16 06:31:16 proxy esmith::event[10863]: Event: static-routes-save FAILED
Mar 16 06:31:16 proxy esmith::event[10839]: Action: /etc/e-smith/events/nethserver-firewall-base-update/S60static-routes-save FAILED: 1 [0.402872]
Mar 16 06:31:17 proxy systemd: [/usr/lib/systemd/system/netdata.service:56] Failed to parse capability in bounding/ambient set, ignoring: CAP_PERFMON
Mar 16 06:31:18 proxy systemd: [/usr/lib/systemd/system/netdata.service:56] Failed to parse capability in bounding/ambient set, ignoring: CAP_PERFMON
Mar 16 06:31:18 proxy esmith::event[10839]: Event: nethserver-firewall-base-update FAILED
Mar 16 06:31:18 proxy esmith::event[11616]: WARNING in /etc/e-smith/db/configuration/migrate//MigrateAmavisdPropertyToRspamd_Issue5394.ns7: value() should not be used on records with properties, use prop() at /usr/share/perl5/vendor_perl/esmith/ConfigDB/Record.pm line 86.
Mar 16 06:31:18 proxy esmith::event[11616]: WARNING: Template processing succeeded for /: 1 fragment generated warnings
Mar 16 06:31:21 proxy systemd: [/usr/lib/systemd/system/netdata.service:56] Failed to parse capability in bounding/ambient set, ignoring: CAP_PERFMON
Mar 16 06:31:22 proxy esmith::event[12759]: WARNING in /etc/e-smith/db/configuration/migrate//MigrateAmavisdPropertyToRspamd_Issue5394.ns7: value() should not be used on records with properties, use prop() at /usr/share/perl5/vendor_perl/esmith/ConfigDB/Record.pm line 86.
Mar 16 06:31:22 proxy esmith::event[12759]: WARNING: Template processing succeeded for /: 1 fragment generated warnings
Mar 16 06:31:23 proxy systemd: [/usr/lib/systemd/system/netdata.service:56] Failed to parse capability in bounding/ambient set, ignoring: CAP_PERFMON
Mar 16 06:31:27 proxy esmith::event[13395]: WARNING in /etc/e-smith/db/configuration/migrate//MigrateAmavisdPropertyToRspamd_Issue5394.ns7: value() should not be used on records with properties, use prop() at /usr/share/perl5/vendor_perl/esmith/ConfigDB/Record.pm line 86.
Mar 16 06:31:27 proxy esmith::event[13395]: WARNING: Template processing succeeded for /: 1 fragment generated warnings
Mar 16 06:31:27 proxy systemd: [/usr/lib/systemd/system/netdata.service:56] Failed to parse capability in bounding/ambient set, ignoring: CAP_PERFMON
Mar 16 06:31:28 proxy esmith::event[13768]: WARNING in /etc/e-smith/db/configuration/migrate//MigrateAmavisdPropertyToRspamd_Issue5394.ns7: value() should not be used on records with properties, use prop() at /usr/share/perl5/vendor_perl/esmith/ConfigDB/Record.pm line 86.
Mar 16 06:31:28 proxy esmith::event[13768]: WARNING: Template processing succeeded for /: 1 fragment generated warnings
Mar 16 06:31:28 proxy systemd: [/usr/lib/systemd/system/netdata.service:56] Failed to parse capability in bounding/ambient set, ignoring: CAP_PERFMON
Mar 16 06:31:29 proxy esmith::event[13899]: WARNING in /etc/e-smith/db/configuration/migrate//MigrateAmavisdPropertyToRspamd_Issue5394.ns7: value() should not be used on records with properties, use prop() at /usr/share/perl5/vendor_perl/esmith/ConfigDB/Record.pm line 86.
Mar 16 06:31:29 proxy esmith::event[13899]: WARNING: Template processing succeeded for /: 1 fragment generated warnings
Mar 16 06:31:30 proxy systemd: [/usr/lib/systemd/system/netdata.service:56] Failed to parse capability in bounding/ambient set, ignoring: CAP_PERFMON
Mar 16 06:31:32 proxy esmith::event[14558]: WARNING in /etc/e-smith/db/configuration/migrate//MigrateAmavisdPropertyToRspamd_Issue5394.ns7: value() should not be used on records with properties, use prop() at /usr/share/perl5/vendor_perl/esmith/ConfigDB/Record.pm line 86.
Mar 16 06:31:32 proxy esmith::event[14558]: WARNING: Template processing succeeded for /: 1 fragment generated warnings
Mar 16 06:31:33 proxy systemd: [/usr/lib/systemd/system/netdata.service:56] Failed to parse capability in bounding/ambient set, ignoring: CAP_PERFMON
Mar 16 06:31:35 proxy systemd: [/usr/lib/systemd/system/netdata.service:56] Failed to parse capability in bounding/ambient set, ignoring: CAP_PERFMON
Mar 16 06:31:35 proxy esmith::event[15343]: WARNING in /etc/e-smith/db/configuration/migrate//MigrateAmavisdPropertyToRspamd_Issue5394.ns7: value() should not be used on records with properties, use prop() at /usr/share/perl5/vendor_perl/esmith/ConfigDB/Record.pm line 86.
Mar 16 06:31:35 proxy esmith::event[15343]: WARNING: Template processing succeeded for /: 1 fragment generated warnings
Mar 16 06:31:36 proxy systemd: [/usr/lib/systemd/system/netdata.service:56] Failed to parse capability in bounding/ambient set, ignoring: CAP_PERFMON
Mar 16 06:31:37 proxy systemd: [/usr/lib/systemd/system/netdata.service:56] Failed to parse capability in bounding/ambient set, ignoring: CAP_PERFMON
Mar 16 06:31:38 proxy systemd: [/usr/lib/systemd/system/netdata.service:56] Failed to parse capability in bounding/ambient set, ignoring: CAP_PERFMON
Mar 16 06:31:43 proxy systemd: [/usr/lib/systemd/system/netdata.service:56] Failed to parse capability in bounding/ambient set, ignoring: CAP_PERFMON
Mar 16 06:31:44 proxy esmith::event[17582]: WARNING in /etc/e-smith/db/configuration/migrate//MigrateAmavisdPropertyToRspamd_Issue5394.ns7: value() should not be used on records with properties, use prop() at /usr/share/perl5/vendor_perl/esmith/ConfigDB/Record.pm line 86.
Mar 16 06:31:44 proxy esmith::event[17582]: WARNING: Template processing succeeded for /: 1 fragment generated warnings
Mar 16 06:31:44 proxy systemd: [/usr/lib/systemd/system/netdata.service:56] Failed to parse capability in bounding/ambient set, ignoring: CAP_PERFMON
Mar 16 06:31:45 proxy esmith::event[18022]: WARNING in /etc/e-smith/db/configuration/migrate//MigrateAmavisdPropertyToRspamd_Issue5394.ns7: value() should not be used on records with properties, use prop() at /usr/share/perl5/vendor_perl/esmith/ConfigDB/Record.pm line 86.
Mar 16 06:31:45 proxy esmith::event[18022]: WARNING: Template processing succeeded for /: 1 fragment generated warnings
Mar 16 06:31:45 proxy esmith::event[18261]: WARNING in /etc/e-smith/db/configuration/migrate//MigrateAmavisdPropertyToRspamd_Issue5394.ns7: value() should not be used on records with properties, use prop() at /usr/share/perl5/vendor_perl/esmith/ConfigDB/Record.pm line 86.
Mar 16 06:31:45 proxy esmith::event[18261]: WARNING: Template processing succeeded for /: 1 fragment generated warnings
Mar 16 06:31:47 proxy systemd: [/usr/lib/systemd/system/netdata.service:56] Failed to parse capability in bounding/ambient set, ignoring: CAP_PERFMON
Mar 16 06:31:47 proxy esmith::event[18644]: WARNING in /etc/e-smith/db/configuration/migrate//MigrateAmavisdPropertyToRspamd_Issue5394.ns7: value() should not be used on records with properties, use prop() at /usr/share/perl5/vendor_perl/esmith/ConfigDB/Record.pm line 86.
Mar 16 06:31:47 proxy esmith::event[18644]: WARNING: Template processing succeeded for /: 1 fragment generated warnings
Mar 16 06:32:05 proxy systemd: [/usr/lib/systemd/system/netdata.service:56] Failed to parse capability in bounding/ambient set, ignoring: CAP_PERFMON
Mar 16 06:32:06 proxy systemd: [/usr/lib/systemd/system/netdata.service:56] Failed to parse capability in bounding/ambient set, ignoring: CAP_PERFMON
Mar 16 06:32:07 proxy systemd: [/usr/lib/systemd/system/netdata.service:56] Failed to parse capability in bounding/ambient set, ignoring: CAP_PERFMON
Mar 16 06:32:08 proxy esmith::event[21058]: WARNING in /etc/e-smith/db/configuration/migrate//MigrateAmavisdPropertyToRspamd_Issue5394.ns7: value() should not be used on records with properties, use prop() at /usr/share/perl5/vendor_perl/esmith/ConfigDB/Record.pm line 86.
Mar 16 06:32:08 proxy esmith::event[21058]: WARNING: Template processing succeeded for /: 1 fragment generated warnings
Mar 16 06:32:08 proxy systemd: [/usr/lib/systemd/system/netdata.service:56] Failed to parse capability in bounding/ambient set, ignoring: CAP_PERFMON
Mar 16 06:32:09 proxy esmith::event[21352]: WARNING in /etc/e-smith/db/configuration/migrate//MigrateAmavisdPropertyToRspamd_Issue5394.ns7: value() should not be used on records with properties, use prop() at /usr/share/perl5/vendor_perl/esmith/ConfigDB/Record.pm line 86.
Mar 16 06:32:09 proxy esmith::event[21352]: WARNING: Template processing succeeded for /: 1 fragment generated warnings
Mar 16 06:32:10 proxy systemd: [/usr/lib/systemd/system/netdata.service:56] Failed to parse capability in bounding/ambient set, ignoring: CAP_PERFMON
Mar 16 06:32:11 proxy systemd: [/usr/lib/systemd/system/netdata.service:56] Failed to parse capability in bounding/ambient set, ignoring: CAP_PERFMON
Mar 16 06:32:12 proxy esmith::event[23021]: WARNING in /etc/e-smith/db/configuration/migrate//MigrateAmavisdPropertyToRspamd_Issue5394.ns7: value() should not be used on records with properties, use prop() at /usr/share/perl5/vendor_perl/esmith/ConfigDB/Record.pm line 86.
Mar 16 06:32:12 proxy esmith::event[23021]: WARNING: Template processing succeeded for /: 1 fragment generated warnings
Mar 16 06:32:12 proxy esmith::event[23269]: WARNING in /etc/e-smith/db/configuration/migrate//MigrateAmavisdPropertyToRspamd_Issue5394.ns7: value() should not be used on records with properties, use prop() at /usr/share/perl5/vendor_perl/esmith/ConfigDB/Record.pm line 86.
Mar 16 06:32:12 proxy esmith::event[23269]: WARNING: Template processing succeeded for /: 1 fragment generated warnings
Mar 16 06:32:14 proxy systemd: [/usr/lib/systemd/system/netdata.service:56] Failed to parse capability in bounding/ambient set, ignoring: CAP_PERFMON
Mar 16 06:32:15 proxy esmith::event[23414]: WARNING in /etc/e-smith/db/configuration/migrate//MigrateAmavisdPropertyToRspamd_Issue5394.ns7: value() should not be used on records with properties, use prop() at /usr/share/perl5/vendor_perl/esmith/ConfigDB/Record.pm line 86.
Mar 16 06:32:15 proxy esmith::event[23414]: WARNING: Template processing succeeded for /: 1 fragment generated warnings
Mar 16 06:32:15 proxy systemd: [/usr/lib/systemd/system/netdata.service:56] Failed to parse capability in bounding/ambient set, ignoring: CAP_PERFMON
Mar 16 06:32:16 proxy systemd: [/usr/lib/systemd/system/netdata.service:56] Failed to parse capability in bounding/ambient set, ignoring: CAP_PERFMON
Mar 16 06:32:17 proxy systemd: [/usr/lib/systemd/system/netdata.service:56] Failed to parse capability in bounding/ambient set, ignoring: CAP_PERFMON
Mar 16 06:32:18 proxy systemd: [/usr/lib/systemd/system/netdata.service:56] Failed to parse capability in bounding/ambient set, ignoring: CAP_PERFMON
Mar 16 06:32:19 proxy systemd: [/usr/lib/systemd/system/netdata.service:56] Failed to parse capability in bounding/ambient set, ignoring: CAP_PERFMON
Mar 16 06:32:20 proxy systemd: [/usr/lib/systemd/system/netdata.service:56] Failed to parse capability in bounding/ambient set, ignoring: CAP_PERFMON
Mar 16 06:32:21 proxy systemd: [/usr/lib/systemd/system/netdata.service:56] Failed to parse capability in bounding/ambient set, ignoring: CAP_PERFMON
Mar 16 06:32:23 proxy systemd: [/usr/lib/systemd/system/netdata.service:56] Failed to parse capability in bounding/ambient set, ignoring: CAP_PERFMON
Mar 16 06:32:25 proxy dockerd: time="2022-03-16T06:32:25.321127779+01:00" level=info msg="stopping event stream following graceful shutdown" error="context canceled" module=libcontainerd namespace=plugins.moby
I personally think that the CAP_PERFMON errors are unrelated but as I’m not sure I’m also including those in this post.
Running the command that is suggested to me in the GUI is successful:
[root@proxy ~]# echo '{"action":"remove","packages":["nethserver-firewall-base-ui"]}' | /usr/bin/setsid /usr/bin/sudo /usr/libexec/nethserver/api/system-packages/update | jq
"state": "running",
"steps": -1,
"event": "Initialization"
"state": "running",
"steps": -1,
"event": "Resolving RPM dependencies"
"state": "running",
"steps": -1,
"event": "Downloading Packages"
"state": "running",
"steps": -1,
"event": "Running Test Transaction"
"state": "running",
"steps": -1,
"event": "Running Transaction"
"status": "success",
"steps": -1,
"event": "Transaction end"
"state": "success"
[root@proxy ~]#
