I’m currently exploring Nethserver as replacement fro my ClearOS7 server.
I’ve installed Nethserver and i’m getting aquinted more and more and I want to move all packages slowely to the new server.
May not the right place to ask but since Nethserver 7 is on the same bases as ClearOS7 i try my luck
On my ClearOS7 server i somehow set a redirection of HTTP to HTTPS and now i want to remove this because it is blocking my redirects.
The problem is that i don’t know how to remove the redirect. It is not setup with .htaccess or a with a Virtual Host setting.
It is only working on my domain and by accessing of my IP
I have no experience with ClearOS or it’s workings/applications. Although the underlying base (minimal) distro might be the same, the management layer/middleware and application ecosystem is totally different.
Correct. It is both based on Centos7 with Apache.
As said i made a change, but i did it manually and with in COS opplications
So what i did was basically a change with the Centos distro, but i don’t know any more how i did it. Maybe a Apache or DNS adjustment
