Is there a predifined/simple way to remove/hide client sender ip from mail sent from the LAN using the postfix MTA of NS that is the FW/GW of the LAN?
Or I need to search some hack for the postfix config?
The problem is due to the storical use of not private IP in the LAN that are in RBL …
