approx. 1/2 year ago I installed asterisk, however I could not remove completly, see here:
However I started living with that without further notice. Now I recieve the following error message from yum update:
Failed to check for updates with the following error message:
Failed to build transaction: asterisk13-core-13.29.2-1.ns7.x86_64 requires libresample.so.1()(64bit)
Questions: yum autoremove was proposed - I would remove 325 MB of files including nethserver-dovecot and base files. May I run
yum autoremove
Is there any other change to get rid of the error?
If I understand correct, the problem is already solved - but for my system the error message still occur within daily update eMail via anacron. Do I need to update something manually?
yum autoremove asterisk13
results in:
Loaded plugins: auto-update-debuginfo, changelog, fastestmirror,
: nethserver_events
No Match for argument: asterisk13
No Packages marked for removal
may I run
yum autoremove
? The pre-output answerd “N” is below
Thanks
Thorsten
: nethserver_events
Resolving Dependencies
--> Running transaction check
---> Package PackageKit-glib.x86_64 0:1.1.10-1.el7.centos will be erased
---> Package at.x86_64 0:3.1.13-24.el7 will be erased
---> Package compat-libical1.x86_64 0:1.0.1-2.el7 will be erased
---> Package dovecot-antispam.x86_64 0:0.0.49-3.ns7 will be erased
---> Package ejabberd.x86_64 0:20.01-0 will be erased
---> Package fann.x86_64 0:2.2.0-6.el7 will be erased
---> Package ghostscript-fonts.noarch 0:5.50-32.el7 will be erased
---> Package janus-gateway.x86_64 0:0.7.6.1-1.ns7 will be erased
---> Package java-1.7.0-openjdk.x86_64 1:1.7.0.251-2.6.21.0.el7_7 will be erased
---> Package java-1.8.0-openjdk.x86_64 1:1.8.0.242.b08-0.el7_7 will be erased
---> Package libXfont.x86_64 0:1.5.4-1.el7 will be erased
---> Package lyx-fonts.noarch 0:2.2.3-1.el7 will be erased
---> Package nethserver-rh-php56-php-fpm.noarch 0:1.0.0-1.ns7 will be erased
---> Package nethserver-unixODBC.noarch 0:1.0.0-1.ns7 will be erased
---> Package openblas-serial.x86_64 0:0.3.3-2.el7 will be erased
---> Package pygobject2.x86_64 0:2.28.6-11.el7 will be erased
---> Package python2-gflags.noarch 0:2.0-5.el7 will be erased
---> Package sclo-php71-php-imap.x86_64 0:7.1.30-1.el7 will be erased
---> Package sclo-php71-php-mcrypt.x86_64 0:7.1.30-1.el7 will be erased
---> Package sclo-php71-php-smbclient.x86_64 0:1.0.0-1.el7 will be erased
---> Package sclo-php71-php-tidy.x86_64 0:7.1.30-1.el7 will be erased
---> Package yum-utils.noarch 0:1.1.31-52.el7 will be erased
--> Finding unneeded leftover dependencies
---> Marking freetds to be removed - no longer needed by nethserver-unixODBC
---> Marking postgresql-odbc to be removed - no longer needed by nethserver-unix ODBC
---> Marking libgfortran to be removed - no longer needed by openblas-serial
---> Marking libmicrohttpd to be removed - no longer needed by janus-gateway
---> Marking libwebsockets to be removed - no longer needed by janus-gateway
---> Marking libnice to be removed - no longer needed by janus-gateway
---> Marking glib to be removed - no longer needed by janus-gateway
---> Marking sofia-sip to be removed - no longer needed by janus-gateway
---> Marking libXcomposite to be removed - no longer needed by java-1.7.0-openjd k
---> Marking java-1.8.0-openjdk-headless to be removed - no longer needed by jav a-1.7.0-openjdk
---> Marking gtk2 to be removed - no longer needed by java-1.7.0-openjdk
---> Marking atk to be removed - no longer needed by java-1.7.0-openjdk
---> Marking giflib to be removed - no longer needed by java-1.7.0-openjdk
---> Marking xorg-x11-fonts-Type1 to be removed - no longer needed by java-1.7.0 -openjdk
---> Marking java-1.7.0-openjdk-headless to be removed - no longer needed by jav a-1.7.0-openjdk
---> Marking python-kitchen to be removed - no longer needed by yum-utils
---> Marking libxml2-python to be removed - no longer needed by yum-utils
---> Marking freetds-libs to be removed - no longer needed by freetds
---> Marking libquadmath to be removed - no longer needed by libgfortran
---> Marking gstreamer1 to be removed - no longer needed by libnice
---> Marking gstreamer to be removed - no longer needed by libnice
---> Marking gupnp-igd to be removed - no longer needed by libnice
---> Marking gupnp to be removed - no longer needed by libnice
---> Marking lksctp-tools to be removed - no longer needed by java-1.8.0-openjdk -headless
---> Marking copy-jdk-configs to be removed - no longer needed by java-1.8.0-ope njdk-headless
---> Marking tzdata-java to be removed - no longer needed by java-1.8.0-openjdk- headless
---> Marking javapackages-tools to be removed - no longer needed by java-1.8.0-o penjdk-headless
---> Marking pcsc-lite-libs to be removed - no longer needed by java-1.8.0-openj dk-headless
---> Marking hicolor-icon-theme to be removed - no longer needed by gtk2
---> Marking gtk-update-icon-cache to be removed - no longer needed by gtk2
---> Marking ttmkfdir to be removed - no longer needed by xorg-x11-fonts-Type1
---> Marking GConf2 to be removed - no longer needed by java-1.7.0-openjdk-headl ess
---> Marking gstreamer-tools to be removed - no longer needed by gstreamer
---> Marking gssdp to be removed - no longer needed by gupnp-igd
---> Marking libsoup to be removed - no longer needed by gupnp
---> Marking python-javapackages to be removed - no longer needed by javapackage s-tools
Found and removing 36 unneeded dependencies
---> Package GConf2.x86_64 0:3.2.6-8.el7 will be erased
---> Package atk.x86_64 0:2.28.1-1.el7 will be erased
---> Package copy-jdk-configs.noarch 0:3.3-10.el7_5 will be erased
---> Package freetds.x86_64 0:1.1.20-1.el7 will be erased
---> Package freetds-libs.x86_64 0:1.1.20-1.el7 will be erased
---> Package giflib.x86_64 0:4.1.6-9.el7 will be erased
---> Package glib.x86_64 1:1.2.10-41.el7 will be erased
---> Package gssdp.x86_64 0:1.0.2-1.el7 will be erased
---> Package gstreamer.x86_64 0:0.10.36-7.el7 will be erased
---> Package gstreamer-tools.x86_64 0:0.10.36-7.el7 will be erased
---> Package gstreamer1.x86_64 0:1.10.4-2.el7 will be erased
---> Package gtk-update-icon-cache.x86_64 0:3.22.30-3.el7 will be erased
---> Package gtk2.x86_64 0:2.24.31-1.el7 will be erased
---> Package gupnp.x86_64 0:1.0.2-5.el7 will be erased
---> Package gupnp-igd.x86_64 0:0.2.5-2.el7 will be erased
---> Package hicolor-icon-theme.noarch 0:0.12-7.el7 will be erased
---> Package java-1.7.0-openjdk-headless.x86_64 1:1.7.0.251-2.6.21.0.el7_7 will be erased
---> Package java-1.8.0-openjdk-headless.x86_64 1:1.8.0.242.b08-0.el7_7 will be erased
---> Package javapackages-tools.noarch 0:3.4.1-11.el7 will be erased
---> Package libXcomposite.x86_64 0:0.4.4-4.1.el7 will be erased
---> Package libgfortran.x86_64 0:4.8.5-39.el7 will be erased
---> Package libmicrohttpd.x86_64 0:0.9.33-2.el7 will be erased
---> Package libnice.x86_64 0:0.1.15-1.ns7 will be erased
---> Package libquadmath.x86_64 0:4.8.5-39.el7 will be erased
---> Package libsoup.x86_64 0:2.62.2-2.el7 will be erased
---> Package libwebsockets.x86_64 0:3.0.1-2.el7 will be erased
---> Package libxml2-python.x86_64 0:2.9.1-6.el7_2.3 will be erased
---> Package lksctp-tools.x86_64 0:1.0.17-2.el7 will be erased
---> Package pcsc-lite-libs.x86_64 0:1.8.8-8.el7 will be erased
---> Package postgresql-odbc.x86_64 0:09.03.0100-2.el7 will be erased
---> Package python-javapackages.noarch 0:3.4.1-11.el7 will be erased
---> Package python-kitchen.noarch 0:1.1.1-5.el7 will be erased
---> Package sofia-sip.x86_64 0:1.12.11-1.ns7 will be erased
---> Package ttmkfdir.x86_64 0:3.0.9-42.el7 will be erased
---> Package tzdata-java.noarch 0:2019c-1.el7 will be erased
---> Package xorg-x11-fonts-Type1.noarch 0:7.5-9.el7 will be erased
Dependencies Resolved
Package Arch Version Repository Size
Removing:
PackageKit-glib x86_64 1.1.10-1.el7.centos @ce-base 480 k
at x86_64 3.1.13-24.el7 @ce-base 95 k
compat-libical1 x86_64 1.0.1-2.el7 @ce-base 595 k
dovecot-antispam x86_64 0.0.49-3.ns7 @nethserver-base 58 k
ejabberd x86_64 20.01-0 @nethserver-updates 28 M
fann x86_64 2.2.0-6.el7 @epel 349 k
ghostscript-fonts noarch 5.50-32.el7 @base 622 k
janus-gateway x86_64 0.7.6.1-1.ns7 @nethserver-updates 7.6 M
java-1.7.0-openjdk x86_64 1:1.7.0.251-2.6.21.0.el7_7
@ce-updates 678 k
java-1.8.0-openjdk x86_64 1:1.8.0.242.b08-0.el7_7 @ce-updates 646 k
libXfont x86_64 1.5.4-1.el7 @ce-base 341 k
lyx-fonts noarch 2.2.3-1.el7 @nethserver 267 k
noarch 1.0.0-1.ns7 @nethserver-base 24
nethserver-unixODBC noarch 1.0.0-1.ns7 @nethserver-base 36 k
openblas-serial x86_64 0.3.3-2.el7 @epel 35 M
pygobject2 x86_64 2.28.6-11.el7 @ce-base 869 k
python2-gflags noarch 2.0-5.el7 @epel 328 k
sclo-php71-php-imap x86_64 7.1.30-1.el7 @ce-sclo-sclo 100 k
sclo-php71-php-mcrypt x86_64 7.1.30-1.el7 @ce-sclo-sclo 47 k
x86_64 1.0.0-1.el7 @ce-sclo-sclo 98 k
sclo-php71-php-tidy x86_64 7.1.30-1.el7 @ce-sclo-sclo 415 k
yum-utils noarch 1.1.31-52.el7 @ce-base 337 k
Removing for dependencies:
GConf2 x86_64 3.2.6-8.el7 @base 6.3 M
atk x86_64 2.28.1-1.el7 @ce-base 1.2 M
copy-jdk-configs noarch 3.3-10.el7_5 @updates 16 k
freetds x86_64 1.1.20-1.el7 @epel 1.5 M
freetds-libs x86_64 1.1.20-1.el7 @epel 1.3 M
giflib x86_64 4.1.6-9.el7 @base 88 k
glib x86_64 1:1.2.10-41.el7 @epel 365 k
gssdp x86_64 1.0.2-1.el7 @ce-base 122 k
gstreamer x86_64 0.10.36-7.el7 @base 3.3 M
gstreamer-tools x86_64 0.10.36-7.el7 @base 94 k
gstreamer1 x86_64 1.10.4-2.el7 @base 4.0 M
gtk-update-icon-cache x86_64 3.22.30-3.el7 @ce-base 58 k
gtk2 x86_64 2.24.31-1.el7 @base 13 M
gupnp x86_64 1.0.2-5.el7 @ce-base 282 k
gupnp-igd x86_64 0.2.5-2.el7 @ce-base 61 k
hicolor-icon-theme noarch 0.12-7.el7 @base 45 k
@ce-updates 95 M
x86_64 1:1.8.0.242.b08-0.el7_7 @ce-updates 107 M
javapackages-tools noarch 3.4.1-11.el7 @base 156 k
libXcomposite x86_64 0.4.4-4.1.el7 @base 34 k
libgfortran x86_64 4.8.5-39.el7 @ce-base 1.1 M
libmicrohttpd x86_64 0.9.33-2.el7 @base 123 k
libnice x86_64 0.1.15-1.ns7 @nethserver-updates 499 k
libquadmath x86_64 4.8.5-39.el7 @ce-base 276 k
libsoup x86_64 2.62.2-2.el7 @ce-base 1.5 M
libwebsockets x86_64 3.0.1-2.el7 @epel 269 k
libxml2-python x86_64 2.9.1-6.el7_2.3 @base 1.4 M
lksctp-tools x86_64 1.0.17-2.el7 @base 227 k
pcsc-lite-libs x86_64 1.8.8-8.el7 @ce-base 46 k
postgresql-odbc x86_64 09.03.0100-2.el7 @base 661 k
python-javapackages noarch 3.4.1-11.el7 @base 65 k
python-kitchen noarch 1.1.1-5.el7 @base 1.4 M
sofia-sip x86_64 1.12.11-1.ns7 @nethserver-base 6.6 M
ttmkfdir x86_64 3.0.9-42.el7 @base 103 k
tzdata-java noarch 2019c-1.el7 @ce-updates 365 k
xorg-x11-fonts-Type1 noarch 7.5-9.el7 @base 863 k
Transaction Summary
Remove 22 Packages (+36 Dependent packages)
Installed size: 325 M
Is this ok [y/N]: n
approx. 223 M of pagages are suggested to be removed - I do not dare that, obviously need packages are concerned.
What do you think: Would it be feasible to reinstall asterisk and subsequent removal?
