Hi all,
From my main server, directly connected to the Internet, I want to redirect toto.org to a LOCAL server.
I create a redirection for toto.org pointing to https://192.168.1.200.
It looks like it redirects only http(s)://toto.org but not http(s)://www.toto.org.
If I create another redirection for www.toto.org then http(s)://www.toto.org is redirected also.
QUESTION:
Is it possible to redirect all CNAME.toto.org (www, smtp, mail, etc) with a single redirection entry ?
Any suggestion appreciated,
Michel-André
Hi all,
Ref: https://httpd.apache.org/docs/2.4/mod/core.html#serveralias
It looks like the ServerAlias *.titi.org
and UseCanonicalName Off
directives is one way to do it but…
For testing, on the LOCAL server (toto.org) I created a new redirection for titi.org and then modified /etc/httpd/conf.d/virtualhosts.conf
of the LOCAL host toto.org i.e. 192.168.1.200.
# Virtual Host titi.org - *:443
# Description : Testing ServerAlias
<VirtualHost *:443>
ServerName titi.org
# Virtual Host titi.org - *:80
<VirtualHost *:80>
ServerName titi.org
Testing the syntax:
# httpd -t
Syntax OK
At the LOCAL server console I can ping anything like:
# ping -c 2 something.titi.org
PING something.titi.org (192.168.1.1) 56(84) bytes of data.
64 bytes from gateway (192.168.1.1): icmp_seq=1 ttl=64 time=0.526 ms
64 bytes from gateway (192.168.1.1): icmp_seq=2 ttl=64 time=2.11 ms
Bu it’s not the LOCAL server toto.org that is responding but the main server 192.168.1.1 .
Even if that’s the way to go, how can I implement that as /etc/httpd/conf.d/virtualhosts.conf
will always be rebuild with a reboot ?
I will continue googling…
Michel-André
