Recommend as reverse proxy
is the caddy on opnsense
with Layer4 proxy
you get even tactical behind it to run
What do you mean? Please add details
i had been tormented for some time behind a reverse proxy tactical rmm
with caddy and opnsense this has now worked well.
also the pages on the nethserver (s) i get along well with this
That’s not enough. You can get your certificate for NethServer and whatever else from behind the caddy.
neth
I even have netbird selfhosted running with it (but only with their new relay). Zitadel didn’t want to work at first but then I set it up as above.
