Hello
I’m traying Nethsecurity 8-23.05.3 for a couple of day but have a problem with a built-in realtek card 811c, not showed in gui. If try to investigate the problem with lspci openwrt show an error “lspci: unable to load libkmod resources: error 2”
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 0c)
Subsystem: Realtek Semiconductor Co., Ltd. Device 0123
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 16
Region 0: I/O ports at e000 [size=256]
Region 2: Memory at d0904000 (64-bit, non-prefetchable) [size=4K]
Region 4: Memory at d0900000 (64-bit, prefetchable) [size=16K]
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=375mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
Address: 0000000000000000 Data: 0000
Capabilities: [70] Express (v2) Endpoint, MSI 01
DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s <512ns, L1 <64us
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 10W
DevCtl: CorrErr- NonFatalErr- FatalErr- UnsupReq-
RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop-
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr+ NonFatalErr- FatalErr- UnsupReq+ AuxPwr+ TransPend-
LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s unlimited, L1 <64us
ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
LnkCtl: ASPM Disabled; RCB 64 bytes, Disabled- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 2.5GT/s, Width x1
TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range ABCD, TimeoutDis+ NROPrPrP- LTR+
10BitTagComp- 10BitTagReq- OBFF Via message/WAKE#, ExtFmt- EETLPPrefix-
EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
FRS- TPHComp- ExtTPHComp-
AtomicOpsCap: 32bit- 64bit- 128bitCAS-
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis+ LTR+ 10BitTagReq- OBFF Disabled,
AtomicOpsCtl: ReqEn-
LnkCap2: Supported Link Speeds: 2.5GT/s, Crosslink- Retimer- 2Retimers- DRS-
LnkCtl2: Target Link Speed: 2.5GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance Preset/De-emphasis: -6dB de-emphasis, 0dB preshoot
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete- EqualizationPhase1-
EqualizationPhase2- EqualizationPhase3- LinkEqualizationRequest-
Retimer- 2Retimers- CrosslinkRes: unsupported
Capabilities: [b0] MSI-X: Enable+ Count=4 Masked-
Vector table: BAR=4 offset=00000000
PBA: BAR=4 offset=00000800
Capabilities: [d0] Vital Product Data
Not readable
Kernel driver in use: r8169
More info of my hardware setup
00:00.0 Host bridge: Intel Corporation Atom Processor Z36xxx/Z37xxx Series SoC Transaction Register (rev 0e)
Subsystem: Mitac Device 0736
Flags: bus master, fast devsel, latency 0
Kernel driver in use: iosf_mbi_pci
00:02.0 VGA compatible controller: Intel Corporation Atom Processor Z36xxx/Z37xxx Series Graphics & Display (rev 0e) (prog-if 00 [VGA controller])
DeviceName: Onboard IGD
Flags: bus master, fast devsel, latency 0, IRQ 89
Memory at d0000000 (32-bit, non-prefetchable) [size=4M]
Memory at c0000000 (32-bit, prefetchable) [size=256M]
I/O ports at f080 [size=8]
Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
Capabilities: [d0] Power Management version 2
Capabilities: [90] MSI: Enable+ Count=1/1 Maskable- 64bit-
Capabilities: [b0] Vendor Specific Information: Len=07 <?>
Kernel driver in use: i915
00:13.0 IDE interface: Intel Corporation Atom Processor E3800 Series SATA IDE Controller (rev 0e) (prog-if 8a [ISA Compatibility mode controller, supports both channels switched to PCI native mode, supports bus mastering])
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 19
I/O ports at 01f0 [size=8]
I/O ports at 03f4
I/O ports at 0170 [size=8]
I/O ports at 0374
I/O ports at f030 [size=16]
I/O ports at f020 [size=16]
Capabilities: [70] Power Management version 3
Kernel driver in use: ata_piix
00:14.0 USB controller: Intel Corporation Atom Processor Z36xxx/Z37xxx, Celeron N2000 Series USB xHCI (rev 0e) (prog-if 30 [XHCI])
Flags: bus master, medium devsel, latency 0, IRQ 90
Memory at d0a00000 (64-bit, non-prefetchable) [size=64K]
Capabilities: [70] Power Management version 2
Capabilities: [80] MSI: Enable+ Count=1/8 Maskable- 64bit+
Kernel driver in use: xhci_hcd
00:1a.0 Encryption controller: Intel Corporation Atom Processor Z36xxx/Z37xxx Series Trusted Execution Engine (rev 0e)
Flags: bus master, fast devsel, latency 0, IRQ 255
Memory at d0500000 (32-bit, non-prefetchable) [size=1M]
Memory at d0400000 (32-bit, non-prefetchable) [size=1M]
Capabilities: [80] Power Management version 3
Capabilities: [a0] MSI: Enable- Count=1/1 Maskable- 64bit-
00:1b.0 Audio device: Intel Corporation Atom Processor Z36xxx/Z37xxx Series High Definition Audio Controller (rev 0e)
Flags: bus master, fast devsel, latency 0, IRQ 3
Memory at d0a10000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [50] Power Management version 2
Capabilities: [60] MSI: Enable- Count=1/1 Maskable- 64bit+
00:1c.0 PCI bridge: Intel Corporation Atom Processor E3800 Series PCI Express Root Port 1 (rev 0e) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 87
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: e000-efff [size=4K] [16-bit]
Memory behind bridge: d0900000-d09fffff [size=1M] [32-bit]
Prefetchable memory behind bridge: [disabled] [64-bit]
Capabilities: [40] Express Root Port (Slot+), MSI 00
Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit-
Capabilities: [90] Subsystem: Mitac Device 0736
Capabilities: [a0] Power Management version 3
Kernel driver in use: pcieport
00:1c.3 PCI bridge: Intel Corporation Atom Processor E3800 Series PCI Express Root Port 4 (rev 0e) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 88
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: d000-dfff [size=4K] [16-bit]
Memory behind bridge: d0600000-d08fffff [size=3M] [32-bit]
00:1f.0 ISA bridge: Intel Corporation Atom Processor Z36xxx/Z37xxx Series Power Control Unit (rev 0e)
Capabilities: [e0] Vendor Specific Information: Len=0c <?>
Kernel driver in use: lpc_ich
00:1f.3 SMBus: Intel Corporation Atom Processor E3800/CE2700 Series SMBus Controller (rev 0e)
Flags: medium devsel, IRQ 4
Memory at d0a14000 (32-bit, non-prefetchable) [size=32]
I/O ports at f000 [size=32]
Capabilities: [50] Power Management version 3
Flags: bus master, fast devsel, latency 0, IRQ 16
Capabilities: [70] Express Endpoint, MSI 01
02:00.0 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
Subsystem: Device 1d1a:0000
Flags: bus master, fast devsel, latency 0, IRQ 19
Memory at d0700000 (32-bit, non-prefetchable) [size=1M]
I/O ports at d020 [disabled] [size=32]
Memory at d0884000 (32-bit, non-prefetchable) [size=16K]
Expansion ROM at d0800000 [disabled] [size=512K]
Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
Capabilities: [70] MSI-X: Enable+ Count=10 Masked-
Capabilities: [a0] Express Endpoint, MSI 00
Kernel driver in use: igb
02:00.1 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
Memory at d0600000 (32-bit, non-prefetchable) [size=1M]
I/O ports at d000 [disabled] [size=32]
Memory at d0880000 (32-bit, non-prefetchable) [size=16K]
any suggestion is very appreciated
