Raid1 degraded, delete the second Volume
Hello,
I’ve been reading here for a few months now and switched from SBS2011 to Nethserver 7.9 about a year and a half ago. Thanks to this forum I was able to solve all the problems I had during the whole time. That’s why I would like to thank all the people who support all the users tirelessly and of course all the developers who make this project possible. THANK YOU!
Recently I moved my installation from an ESXi 6 to an ESXi 8. Since I wanted to get rid of my NFS mounts, I chose a fresh install followed by a backup restore, which worked fine so far. Unfortunately, I was careless during setup and created a Raid1 volume for both the SWAP file and the system, which is of course completely unnecessary since the ESXi’s datastores already consist of a Raid5.
Now I have the problem that my Raid1 is shown as degraded, can I correct this error without starting all over again?
Hi and welcome to NethServer Community,
here are instructions to either remove the missing disks from the RAID1 or completely remove mdadm (please be sure to have a backup first!!!):
Hi Markus,
thank you for your answer and the link. I have to look at it again in peace, that reads for me unfortunately not so simple.
Are there any disadvantages (e.g. performance) if I leave it as it is now?
If I make a snapshot on the ESXi before this intervention, can I then in case of an error back again and everything works again or helps here then also no snapshot more?
I’d suggest a full, independent Backup on ESXi, it’s fast enough… :slight_smile:
Hi Andy,
Okay, then I will create a complete backup before. Do I have any disadvantages if I leave the faulty Raid1 first still so. I have to deal with the topic and the article of Markus more intensively, that sounds unfortunately not so simple for me.
Regards
Erwin
@Niwre
Hi Erwin
As an old administrators adage is:
Better a backup to many, than one to little…!
That’s the main advantage of virtualization - snapshots and backups… :slight_smile:
But I might suggest having a look at Proxmox, my choice of Hypervisor (2015) after using VMWare since before 2000!
Especially with PBS, fast incremental Backups, also offsite if needed. :slight_smile:
A lot of stuff included that VMWare has a price tag on (hefty one at that!).
Disadvantages:
None, no matter how you may goof off, a good backup (Test it!) saves your butt.
You won’t be any better off, but you at least still have the status quo - as often as you need until you can fix it. Or backup Restore to a newer VM without the RAID to begin with…
Hi Andy,
Thanks for your help. I’ve been reading the forum for a while now and I really like your posts, so I know your preference for Proxmox. I’ve thought about switching to Proxmox several times, but habit and a good running system have kept me away. But postponed is not canceled, let’s see what the future brings. :grinning:
I will now think about how I will solve the issue, a backup restore to a new VM would also be a possible scenario, so I have done it recently.
Thanks again for your support, now it’s up to me.
Regards
Erwin
As always, with a disaster recovery job in front of you:
Good luck!
It’s not only any skills as administrator, but one certainly doesn’t need a several hour city wide blackout during the critical phase… :slight_smile:
Hello,
@mrmarkuz
I was able to fix the problem with your instructions and thus avoided another disaster recovery. I went for the first one “Lazy and easy”, was the easier way for me and worked fine. Thanks for the link to the tutorial.
@Andy_Wismer
A blackout during a disaster recovery would be terrible of course, I hadn’t even thought of that during my first restore. :innocent:
It does not belong in this thread, but I would still like to thank you for your many contributions, I have already drawn good tips from it. I have adjusted my DNS settings, for example, after a contribution from you. :slightly_smiling_face:
Erwin
