quadpr5
(Oliver Johnston)
January 20, 2019, 8:19pm
1
NethServer Version: 7.6
Module: * Raid/Luks
I have been testing raid 1 and LUKS on a test server so I can get upto speed with it should I have any issues.
if I disconnect either drive the system will attempt to boot however eventually I get an error complaining the system can’t find any LUKS devices!
The shell then drops to emergency mode.
If I plug both drives in I then have a bootable system.
Once booted I have 3 raid dives and 2 luks drives showing and mounted.
Have I simply setup the disks incorrectly during install?
Many thanks.
m.traeumner
(Michael Träumner)
January 21, 2019, 1:01pm
2
@support_team Can somebody help?
quadpr5
(Oliver Johnston)
January 21, 2019, 8:37pm
3
Hi Guys, looks sorted now.
Randomly Its started to work now and also it appears that the stick of RAM was faulty, maybe the issues with LUKS were RAM related.
I’m now on with some disaster recovery tests to get familiar with the RAID/VGroup/LUKS combination.
I’m thinking is a hardware raid card a better setup? It removes to me some complexity.
Whats the thinking Hardware raid vs software raid on a small office linux server with LUKS?
Cheers.
quadpr5
(Oliver Johnston)
January 21, 2019, 8:50pm
4
Also, must mention this guide, it helped me a LOT!
Not disti specific, however I run some Centos and Debian based stuff and it works for both
m.traeumner
(Michael Träumner)
January 22, 2019, 8:13am
5
Please have a look at the linked article, it’s a good description about the difference between Hard- and Softwareraid.
https://www.neweggbusiness.com/smartbuyer/components/whats-difference-hardware-raid-vs-software-raid/
If you think this is the solution please mark it as solved.
Now we have an amazing feature on our community platform which helps to mark a topic as SOLVED
As the OP (topic creator) you will have a button that allows you to accept an answer
[image]
Accepted answers are highlighted in the topic list:
[image]
Accepted answers are highlighted on the initial topic:
[image]
This kind of action is enabled only for topic into the Support category
Happy support!
