Quiz question Is there a way to integrate Jitsi into Mattermost?
Hi friends,
Is there a corresponding plugin for MM? And if so, can it be easily integrated?
IiRC you can start a jitsy chanel from mattermost, no need to host the jisty services
However now jitsy plugin needs to be installed manually
Hi @stephdl
If I remember correctly, in the current MM version of NS8 it is not possible to install additional plugins from their marketplace. Or I have overlooked a setting in the admin panel…
manually you need to enable the file upload I think but not tested (in the config.json) then you can upload custom plugin
It’s also possible to install manually:
Install wget:
dnf install wget
Enter MM environment:
runagent -m mattermost1
Download the jitsi plugin:
wget https://github.com/mattermost-community/mattermost-plugin-jitsi/releases/download/v2.1.0/jitsi-2.1.0.tar.gz
Extract the plugin:
tar -xzf jitsi-2.1.0.tar.gz
Copy plugin into jitsi container:
podman cp jitsi mattermost-app:/mattermost/plugins/
Now the plugin can be enabled and configured in the MM system console:
Hi @mrmarkuz
Generally it works. But the 2FA authentication set up in MM does not work when you set up a conference via the plugin. My hope was that this would provide a little more security for Jitsi.
