So if I install the Zabbix Agent2 version 6 manually myself I can use the systemctl restart command. I do not use the signal-event command.
Is the above a correct statement?
Thank you.
Thank you.
Yes, the statement is correct.
Just sharing.
Finally have notification on spammer.
Directly disable related account.
Next step, enable 2FA to reduce user’s account used by spammer.
Thanks @mrmarkuz @stephdl @Andy_Wismer and all others that share tips/trick/info.
