Hi, I realize this not a Nethserver question but I did follow the procedure to install Zabbix 5.0 on Nethserver which worked great. I am trying to monitor the health of my disks which has resulted in failures so far. I tried this procedure under Proxmox :
The procedure has to be adapted a bit, no need for SUDO under Proxmox for example. There is also a mention of a zabbix-agent user which I don’t know where that comes from.
Anyways, if someone did try to install SMART monitoring using this procedure or has a better one, I would appreciate it.
Short ( I hope smooth) further introduction in the linux-world,
It’s good practice to run a daemon (service) with it’s own restricted user, just to be sure this daemon can’t be a devil.
So on installation a user and a group is created for the service-application you just installed. And typically this user is granted privileges to do/run only that it needs to do. hence the :
The last line means the smartctl-storage-discovery.sh bash-script runs as zabbix with SUperuserDO (=root) privilages. The author should have used “sudo” in the script where needed instead of running the whole script as root.
Note: do not see malicious (devils) code in the bash script, hence a little mistake
From a security respective It better to set root as user (=owner) and give the zabbix group (with one member: zabbix) less privileges. And it makes is better “readable” as in code: if a sysadmin sees this the intentions are very clear.
