Can one explain me the difference in the proxy settings between: whitelist for global domains and whitelist for blocked urls?
Speaking of proxy - I don’t see any tab cache for those settings in my cockpit under Web Proxy & Filter, as they are described in the documentation, anyone an idea why and where would those settings be located? Following the kiss princible I have only enabled transparent mode for green zone.
And a follow up question if I may:
Some time ago I had discovered that squid did not block the configured file extensions, and if I remember correctly I was told this is because those downloads were using a https connection. Does this limitation apply generally or only in transparent mode for example, or is it more a thing of (mis-)configuration?
