Question about Fail2ban
**NethServer Version: Latest version
Hi I have install two nethservers, one for webmail and one for nextcloud.
Both goes public with HTTPS but I wonder if I can use Fail2ban to make them more secure.
I like to make a block so if someone write the password (or username) wrong 5 times it going to ban at least 1 hour.
Have look in the guide and is not so easy for me to understand :slight_smile: but first I need to make sure it can connect to nextcloud and roundcube webmail.
Yes you can. Pre-configured jails are available for roundcube, nextcloud and other services.
Here is a partial sample of the configuration options:
fail2ban-advanced_settings
For more granular control, the MaxRetry attempts can be customized per jail from the command line (through NethServer/e-smith config database).
