Pseudo-Bug: Default 90 s systemd start timeout breaks Passbolt and Nextcloud after an unclean shutdown — and during module updates
Disclaimer: Analyzed and Summarized with AI
After a power outage at home my node came back up but two modules did not: Passbolt and Nextcloud, both returning Bad Gateway through Traefik. I diagnosed both and found the same mechanism, so I am posting it here as @mrmarkuz suggested — maybe others have seen it too.
Environment
  • NS8 core 3.21.0
  • Modules: passbolt1 1.0.6, nextcloud1 1.7.3 → 1.7.4
  • Node: single node, Proxmox VM, 16 GiB RAM
  • Images: passbolt 5.14.3-1-ce-non-root, mariadb 10.11.18 (Passbolt), mariadb 10.6.27 (Nextcloud)
  • Storage: ZFS RAIDZ1. Relevant caveat: at the time of the incident the pool was two Samsung SSDs plus one WD Red HDD — mid-migration to all-SSD. In a RAIDZ1 the slowest member sets the pace, so write latency was at HDD level. See the measurement at the end.
I had rebooted this system many times before without trouble. What was new was an unclean shutdown.
The common mechanism
None of the affected units set their own TimeoutStartSec, so the user manager default applies: DefaultTimeoutStartUSec=1min 30s. That limit applies per phase — every ExecStartPre and every ExecStartPost gets its own 90 s.
After an unclean shutdown InnoDB needs crash recovery, and all modules start concurrently competing for the same I/O. The budget runs out before the work finishes.
Case 1 — Passbolt: the DB phase times out and the service cannot self-recover
passbolt-db.service uses an unbounded wait loop as its second ExecStartPost:
while ! mysqladmin ping -h localhost -P 3306 -u root; do sleep 1; done
It has no timeout of its own and is terminated only by the systemd start timeout. Journal:
08:43:30  ping loop begins
08:44:56  passbolt-db.service: start-post operation timed out. Terminating.   (86 s)
08:45:16  InnoDB: Starting crash recovery from checkpoint LSN=33302486
08:45:41  InnoDB: To recover: 246 pages
08:45:58  mariadbd: ready for connections
08:46:06  State 'stop-sigterm' timed out. Killing.  → SIGKILL
08:46:47  Failed with result 'timeout', restart counter 1
The database became available 62 s after systemd had given up, and was SIGKILLed 8 s after announcing readiness. That kill leaves the redo log unclean again, so the next automatic retry needs crash recovery once more and hits the same timeout. Restart=always kept the service in that loop (retries at 08:47:50, 08:55:42, 09:03:07, all failed). Only a manual module restart broke it — the start at 09:11:38 completed in 34 s because by then the redo log was clean.
Case 2 — Nextcloud: pod creation times out first, then nginx burns its retry counter
08:44:49  Starting nextcloud.service
08:46:19  start-pre operation timed out    (exactly 90 s)
Consequence: nextcloud-app.service fails with result 'dependency' because the pod does not exist. nextcloud-nginx starts anyway with --volumes-from nextcloud-app and fails with:
Error: looking up container "nextcloud-app" for volumes-from: no container with name or ID "nextcloud-app" found
Ten times in a row, then Start request repeated too quickly — after which Restart=always no longer applies and the unit sits in failed state indefinitely. nextcloud-db.service hit the same start-post timeout as Passbolt.
Case 3 — the same timeout hits a normal module update
This one worries me most. Updating nextcloud1 from 1.7.3 to 1.7.4 through the Software Center: the Software Center reports 100 % success, but the instance is left in maintenance mode with needsDbUpgrade: true and is unreachable.
10:04:28.811  nextcloud-app: Turned on maintenance mode
10:05:53.852  nextcloud-app.service: start-post operation timed out. Terminating.
10:07:24.102  State 'stop-sigterm' timed out. Killing.
The entrypoint enables maintenance mode and starts the occ upgrade; 85 s later systemd aborts the start phase and 90 s after that sends SIGKILL — killing the upgrade mid-migration. Running occ upgrade manually afterwards completed it. A schema migration being killed by a start timeout is a data risk, not just an availability problem, and a silently failed update reported as successful is hard to notice.
This has now happened on two independent systems here.
Case 4 — nextcloud-app never gets through its post-start chain
After a second power outage the same day (this time with a ZFS resilver running, so the pool was genuinely slow), nextcloud-app.service stayed in activating (start-post) indefinitely while the container itself was healthy (fpm is running, ready to handle connections).
The unit has three post-start steps sharing one 90 s budget:
ExecStartPost=runagent wait-startup
ExecStartPost=runagent setup-smtp
ExecStartPost=runagent setup-ldap
setup-ldap sets every LDAP config value through its own occ call, each spawning a PHP process in the container — observed at roughly 1 s per call (occ ldap:set-config s01 ldapGroupDisplayName cn, then occ ldap:set-config s01 ldapPort 20001, …). With ~20 values plus the other two steps the budget is gone, systemd kills the service, and the chain restarts from scratch. It never converges. A drop-in with TimeoutStartSec=1800 let it finish.
While reading wait-startup (~/.config/bin/wait-startup) I noticed three things:
  1. The except branch calls continue before time.sleep(1) — on errors the loop burns all 60 attempts in milliseconds instead of 60 seconds.
  2. After 60 unsuccessful attempts the script exits 0. Failure to reach the app is not signalled.
  3. There is no timeout on the individual occ call. One hanging call blocks the whole ExecStartPost until systemd aborts at 90 s.
What it is not
  • Not memory pressure. 16 GiB total, ~2.4 GiB used, swap untouched. status=137 matches the SIGKILL from podman stop -t 10 in ExecStop, not OOM.
  • Not a corrupt database. Crash recovery completed cleanly every time.
  • Not modified units. No drop-ins were present before I added one, and I have since removed it.
On the disk speed question — with a measurement
@mrmarkuz pointed out that fast disks are a system requirement and that the apps are tested on fast storage. That is fair and it applies here: with one HDD still in the RAIDZ1, pod create took 65 s, container remove 40 s, and a trivial printf into a container 21 s.
The disk migration is now complete — all-SSD RAIDZ1, resilver finished without errors. Reference measurement on the same node:
# time runagent -m nextcloud1 systemctl --user restart nextcloud-app.service
real    0m26.955s
27 s for the full restart including the three-step post-start chain, i.e. comfortably inside the 90 s default with a factor of ~3.3 to spare. So slow storage was clearly what pushed these operations past the limit.
My argument is that slow storage exposes these issues rather than causing them:
  • SIGKILLing a mariadbd that reported ready for connections 8 s earlier is what turns one slow start into a non-converging loop. A failed start should not leave the data directory in a state that guarantees the next attempt is slow too.
  • A schema migration should not run under a start timeout at all.
  • A module update killed mid-migration should not be reported as successful.
Note the 27 s figure was measured with a clean database, no crash recovery, and no other modules starting simultaneously. Those three conditions together are what broke the 90 s budget.
Suggestions
  1. Explicit TimeoutStartSec on the DB units, sized for crash recovery on a loaded host rather than a warm start.
  2. Bound the readiness wait itself (the mysqladmin ping loop, the occ status loop) so it is not governed by the systemd start timeout as a side effect.
  3. Avoid SIGKILLing a running mariadbd on start failure.
  4. Nextcloud: nginx retrying ten times against a non-existent nextcloud-app and burning its retry counter is fragile — a dependency would be more robust than a blind retry.
  5. Consider whether setup-ldap needs one occ invocation per config value.
Already fixed
@mrmarkuz confirmed a separate typo I found in nextcloud-nginx.service (%t/nextcloud-.pid instead of %t/nextcloud-nginx.pid, so the cleanup line never matches the actual PID file) and opened a PR: Fix typo by mrmarkuz · Pull Request #257 · NethServer/ns8-nextcloud · GitHub
Also, for anyone hitting the maintenance-mode case: you can simply run occ upgrade — no need for the full podman exec -u www-data nextcloud-app php occ upgrade I used.
Happy to provide full journals for any of the four cases.
Oh, and this morning I noticed webserver was also affected, but now, after resilvering, I am running on three SSD while the webserver case seems to be a relict from yesterday
:slight_smile:
Thanks a lot for the writeup, and for confirming the SSD details — that made this much easier to pin down.
In hindsight, running a module update while a ZFS resilver was in progress probably wasn’t the best timing — but that’s unrelated to the power outage itself, which obviously wasn’t on you. With the Christmas coming up, a UPS might be a nice gift for that node.
For Nextcloud, we’re going to raise TimeoutStartSec on the affected units, the same way it’s already handled for the postgres service in ns8-webtop — Nextcloud keeps getting heavier, so it makes sense to give it more room by default rather than relying on the systemd default.
For Passbolt, the fix needs two parts: a larger TimeoutStartSec on passbolt-db.service, plus a bounded retry limit in the readiness check itself so it fails fast and explicitly instead of waiting the full timeout — there’s no point waiting up to 10 minutes for a database that’s stuck. We’ll follow the same pattern already used for wait-postgres-init in ns8-webtop.
Thanks again for the thorough report.
Hi @stephdl
sorry, maybe it was too much text at once, or I did not review clearly. So the latter is not related to the topic itself but for clearification:
No, there was no module update during ZFS resilver, the sequence was:
a) First Blackout at night (approx. 23:00) while family was sleeping
b) Detection / solution of not starting modules at morning around 6:00, server on 2x SSD and HDD
c) Module update (accomplished at approximatly 8:00, while I was waiting for an electrician)
d) Second (scheduled) Blackout approx. 10:00, interruption during shutdown as the electrician pulled the fuses before I gave status update - the server was not clean
e) Startup at 10:15, but not came to full boot up, as the
f) third Blackout (approx. 10:30)
g) power up (approx. 12:15),
h) exchange of HDD-> SSD (because the server was down anyway), server ZFS still on 2x SSD and HDD,
i) approx. 12:30: solution of not starting modules similar as in the morning,
i) resilver started at 15:00 overnight (but finished approx. 20:00)
Amendment to b): two main fuses (L1, L2) at home entrance were burned, while L3 was still active. I had not to call a simple electrician, but I needed repair by the supplier (failure before first fuse). At 6:00 I was bridging fridges and the server via cables to L3.
I have a UPS in place, but the first blackout was for more than 8 h while the UPS lasts vor 30-50 min. The second blackout was just 20 min, while the third was 2 h. Even though, the battery was exhausted from the first blackout and had no time to recover.
Best
out of scope of this, but normally a UPS can communicate with serial (yes I am old) or by usb with the server and stop it when the battery goes off
yes, correct, but you must not forget to configure …most blackout until now were << 20 min, so there was no need to act until now.:innocent:
Yes I discovered the same issue… But I compounded my issue by trying to move logs into tmpfs, which broke all sorts of /run/ parts for podman/docker.
Running a proxmox system with 8TB CBR slow disks in RAID 1 caught this hard timeout when restarting on quite a few modules. I ended up writing a ns8-fix-boot.sh file that checks each service, and restarts/starts as required. The only advantage of the script is the detection of failed loaded docker parts, like nextcloud-nginx and restarting the failed service, waiting for service to start, then checking next service, in a reliable sequence. At least I can start the server now in under ten minutes instead of 30+ minutes.
Of course the smaller 2TB SSD proxmox units work well, and don’t have this time out issue. Unfortunately I couldn’t convince management to pay thousands of dollars for enterprise SSD drives for the main system, so had to work around the handicap of slow spinning disks.
Management love savings — as long as the savings land inside this year’s budget.
In my case the decision was made for me: one of the HDDs started throwing errors around May, so a replacement was due anyway. Three SSDs came to roughly 1600 EUR, which hurt. But the WD Reds they replaced were about 9 years old — some 80,000 hours of uninterrupted runtime and exactly one SMART error in all that time. Hard to complain about that.
And before anyone points at the power bill, I ran the numbers on my box for those same 9 years:
Disks 1,600 EUR
Power: 0.4 kW × 8,760 h × 9 a = 31,536 kWh at 25 ct avg 7,884 EUR
Total 9,484 EUR
That is 88 EUR/month. The server itself was free — collected from a waste bin.
Now the rented equivalent, 50 TB plus mail and chat. In a Microsoft 365 tenant you get 1 TB plus 10 GB per user included, so you buy ~49 TB of Extra File Storage at roughly 0.18 EUR/GB/month — about 8,800 EUR per month, near 950,000 EUR over 9 years, licences on top. Google Workspace is far kinder because storage is pooled: 10 × Business Plus at 25.30 EUR gives you exactly 50 TB and lands at ~27,300 EUR for the 9 years.
So: 9,500 EUR self-hosted against 27,000 to 950,000 EUR rented. Even with spinning rust and a 30-minute boot, the on-prem box is not the expensive part of the equation.
But the money is only half of it, and honestly not the half I care about most.
My data stays mine. I stay the controller under GDPR, and there is no processor and no third-country transfer anywhere in the chain — no DPA to negotiate, no sub-processor list to audit, no clause that changes at the vendor’s next renewal. Integrity is mine to verify: my checksums, my snapshots, my restore test, my timeline.
And then there is the part no subscription sells you: flexibility. NS8 gives me Nextcloud with well over 150 apps, plus everything else in the module catalogue — mail, LDAP/AD, Collabora, Passbolt, monitoring, whatever the next problem turns out to need. When a requirement shows up, I install something and try it. I don’t open a ticket, I don’t wait for a roadmap, I don’t get told the feature exists two tiers up. For every problem, a solution — and if there isn’t one yet, I can build the module myself.
Bonus argument for the next budget round: 50 TB of initial upload at 50 Mbit/s upstream is 93 days of continuous transfer. Same again for a full restore.
The NS8 additional volumes feature (milestone 8.7) is worth considering here, not only for cost reasons. According to the documented requirements, app-dedicated storage should be on SSD by default, and HDD is allowed only for apps that explicitly support it for large files (such as Nextcloud’s file storage) — SQL databases, including Nextcloud’s, always use the default storage. Since the 90s systemd timeout is often caused by slow I/O during startup (LDAP binds, DB checks, mounts), moving the DB/metadata volume to SSD while keeping bulk file storage on HDD should fix the real cause of the problem for Passbolt and Nextcloud, instead of just increasing the timeout to hide it. – System requirements | NethServer 8 documentation
Follow-up: Case 3 happened again today, this time on a second, independent NS8 cluster (Proxmox VM on slow HDD storage), during the regular nextcloud module update to NC 33.0.9. Again, the Software Center reported success, while the instance was left in maintenance mode.
Journal of the module’s user manager:
15:46:16  Starting Podman nextcloud-app.service...
15:47:59  nextcloud-app.service: start-post operation timed out. Terminating.
15:49:29  State 'stop-sigterm' timed out. Killing.  → SIGKILL
15:49:43  Failed with result 'timeout'
15:49:44  Scheduled restart job, restart counter is at 1
15:50:03  Started Podman nextcloud-app.service   (19 s, upgrade skipped)
Result: code at 33.0.9.1, database still at 33.0.8.2, maintenance: true, needsDbUpgrade: true. A manual occ upgrade completed it. The integrity check alone took 81 s on this storage.
Two observations that may help others detect this:
  1. Loglevel left at 0. The Nextcloud updater switches loglevel to Debug at the start of an upgrade and restores it at the end. When the upgrade is killed, it stays at 0, and a subsequent manual occ upgrade then “restores” 0 as the previous value. A loglevel of 0 after a module update is a strong hint that the upgrade was aborted.
  2. ExecStartPost=- does not help. I had a drop-in with ignored-error ExecStartPost lines. The - prefix only ignores a non-zero exit code; a timeout still fails the unit.
Workaround in place: drop-in nextcloud-app.service.d/timeout.conf with TimeoutStartSec=900. Custom drop-ins in that directory survived the last two module updates.
@stephdl: in main, nextcloud-app.service still has no TimeoutStartSec. Is the change you mentioned planned for an upcoming release?
@davidep: agreed that moving DB/metadata to SSD addresses the root cause, and I will plan for it. But SSDs cost money, and as @Turbond described, that budget is not always available — so slow storage will remain a reality on a number of installations for some time. An update that kills a schema migration, leaves the instance in maintenance mode, and is still reported as successful seems worth guarding against independently of storage speed.
we need more log thorsten, no debug is possible with 5 lines :slight_smile: attach the full log to a gist please
sorry, yes, you are right, I just filtered on the most relevant lines, will do so, but today, I am ooo with just limited access to the cluster.
it is important to understand the history, the timeshift of the event, I am with automatic updates and I do not have this issue
