NethServer Version: NethSecurity 8 23.05.3-ns.1.1.0
Module: Internet/Proxy
How can I use Nethsecurity to run outgoing data traffic via a proxy in the same network?
However, a loop should be avoided.
Nicky
Nicky
Currently there’s no proxy available on NethSecurity.
From the manual:
The following features are not migrated to NethSecurity:
- Web proxy (Squid) and filter (ufdbGuard)
AFAIK OpenWrt (that NethSec is based on) has a squid package so it’s not impossible but needs to be installed/configured manually. I never tested, there may be conflicts with existing packages/configurations…
But you can use the new DPI filter to block outgoing data traffic
