I’m running two nearly identical 6.4.13 proxmox boxes. Config/setup of the first machine looks like this:
pvs
PV VG Fmt Attr PSize PFree
/dev/sda3 pve lvm2 a-- <837.83g 15.99g
vgs
VG #PV #LV #SN Attr VSize VFree
pve 1 5 0 wz–n- <837.83g 15.99g
lvs
LV VG Attr LSize Pool Origin Data% Meta% Move Log Cpy%Sync Convert
data pve twi-aotz-- 679.95g 27.25 1.58
root pve -wi-ao---- 96.00g
swap pve -wi-ao---- 32.00g
vm-100-disk-0 pve Vwi-aotz-- 360.00g data 36.70
vm-101-disk-0 pve Vwi-aotz-- 60.00g data 88.55
df -h
Filesystem Size Used Avail Use% Mounted on
udev 16G 0 16G 0% /dev
tmpfs 3.2G 9.3M 3.2G 1% /run
/dev/mapper/pve-root 96G 92G 4.3G 96% /
tmpfs 16G 43M 16G 1% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 16G 0 16G 0% /sys/fs/cgroup
/dev/fuse 30M 16K 30M 1% /etc/pve
/dev/sdd1 3.7T 90G 3.6T 3% /media/backup
/dev/sdb1 280G 318M 279G 1% /media/cache
tmpfs 3.2G 0 3.2G 0% /run/user/0
And the second one:
pvs
vgs
pve 1 8 0 wz–n- <837.83g 15.99g
lvs
data pve twi-aotz-- 679.95g 32.50 1.84
snap_vm-100-disk-0_vanilla pve Vri—tz-k 360.00g data vm-100-disk-0
snap_vm-200-disk-0_migriert pve Vri—tz-k 5.00g data vm-200-disk-0
snap_vm-200-disk-0_vanilla pve Vri—tz-k 5.00g data vm-200-disk-0
vm-100-disk-0 pve Vwi-aotz-- 360.00g data 59.94
vm-200-disk-0 pve Vwi-a-tz-- 5.00g data 55.36
df -h
tmpfs 3.2G 50M 3.1G 2% /run
/dev/mapper/pve-root 96G 8.1G 88G 9% /
/dev/fuse 30M 20K 30M 1% /etc/pve
/dev/sdc1 2.8T 870G 1.9T 32% /media/backup
What I don’t understand is the difference between the /dev/mapper/pve-root. The first machine shows 96% data use and the second one only 9%.
Here some more info:
On both machines:
cat /etc/fstab
/dev/pve/root / xfs defaults 0 1
/dev/pve/swap none swap sw 0 0
proc /proc proc defaults 0 0
UUID=8b87e2b6-43af-4bec-b7e1-a8751abbd6f4 /media/backup xfs defaults,noatime,auto,nofail 0 2
UUID=cb9edf38-9e9e-489e-bd4f-18126347b3d6 /media/cache xfs defaults,noatime,auto,nofail 0 2
and
cat /etc/vzdump.conf
vzdump default settings
tmpdir: /media/cache
#dumpdir: DIR
#storage: STORAGE_ID
#mode: snapshot|suspend|stop
#bwlimit: KBPS
#ionice: PRI
#lockwait: MINUTES
#stopwait: MINUTES
#size: MB
#stdexcludes: BOOLEAN
#mailto: ADDRESSLIST
#maxfiles: N
#script: FILENAME
#exclude-path: PATHLIST
#pigz: N
and:
machine 1:
ncdu / shows: 85.3 GiB [##########] /media
lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 838.3G 0 disk
├─sda1 8:1 0 1007K 0 part
├─sda2 8:2 0 512M 0 part
└─sda3 8:3 0 837.9G 0 part
├─pve-swap 253:0 0 32G 0 lvm [SWAP]
├─pve-root 253:1 0 96G 0 lvm /
├─pve-data_tmeta 253:2 0 7G 0 lvm
│ └─pve-data-tpool 253:4 0 680G 0 lvm
│ ├─pve-data 253:5 0 680G 0 lvm
│ ├─pve-vm–100–disk–0 253:6 0 360G 0 lvm
│ └─pve-vm–101–disk–0 253:7 0 60G 0 lvm
└─pve-data_tdata 253:3 0 680G 0 lvm
sdb 8:16 0 279.4G 0 disk
└─sdb1 8:17 0 279.4G 0 part /media/cache
sdd 8:48 0 3.7T 0 disk
└─sdd1 8:49 0 3.7T 0 part /media/backup
sr0 11:0 1 1024M 0 rom
machine 2:
ncdu / shows: 867.0 GiB [##########] /media
lsblk
│ └─pve-vm–200–disk–0 253:7 0 5G 0 lvm
sdc 8:32 0 2.7T 0 disk
└─sdc1 8:33 0 2.7T 0 part /media/backup
I can’t remember how I increased/added the space on the second machine. Any help is appreciated.
regards,
stefan
