Protect roundcubemail with 2fa
Has anyone given consideration to applying 2fa to our Roundcube install?
IIRC the plugin must be enabled inside roundcubemail configuration
It’s already there? I can’t find it in either the roundcube or mail settings.
It sems they are not official
This one is the most used, but you have other
https://packagist.org/search/?type=roundcube-plugin&tags=Authentication
Maybe it will work better with the last version of roundcube I offer on my repository
Is it worth considering (I believe it is) to add the 2fa plugin for roundcube to our official pkg?
I propose an updated version of roundcubemail, I could check if it is possible
I think I got it workable with 1.4.8, thinking on the best way to bundle it in the rpm, coming soon
released
https://wiki.nethserver.org/doku.php?id=roundcubemail#fa
Works well. Thank you.
Do you manually update the repo? 1.4.8 installed and I see they’re up to .9.
1.4.9 released, just tested that roundcube works, not tested 2FA, please ping us if not
