Hi, I am a dad wanting to protect my home network. I have (very) little networking knowledge but ready to learn. I have successfully installed the latest 64 bit Nethserver on my DELL GX620. Very easy to install and it recognised both add-on PCI network cards. I can access the admin GUI and installed almost everything I can find on the software center
So, I am ready for the next step. I wonder if Nethserver can accommodate my setup? I don’t know the correct terminology or proper symbols but I hope you can understand my LAN. Any feedback is greatly appreciated.
My setup is almost identical to yours, only difference is that the WAN port for the server is connecting to a Fibre Modem provided by my ISP and I am using OpenVPN for the VPN instead of L2TP.
NethServer has some additional feature for the web filtering which will add some extra/added layer of protection for you as well.
[quote=“jackyes, post:10, topic:3160, full:true”]
i don’t like opendns (why open in the name?? ) i prefer have the control to block what i want. (don’t want to spend money )[/quote]
I use the free version thinking of going for paid one at some stage. Its quiet good actually because it blocks nasties from my family. I also have Qustodio on each desktop (bar mine).
As @jackyes states, the web content filter will go a long to helping with the solution. On the “protected lan”, you can set Nethserver to serve out the IP address for whichever DNS server you wish to use and then with the firewall rules, you can create a rule that limits the DNS ports to only those DNS servers which you wish to use.
