Well, maybe Zammad could be sorted as Project Management.
Or… should be better use something like Trello? Asana… Or maybe something else?
github gets a dashboard, maybe simple but efficient
GitHub as Jira are designe for software develompent, and as far as i can remember, the first one is… online, not on NethServer…
You can use something like taiga but I don’t know if it’s installable on NethServer
Openproject seems available for CentOS.
https://www.openproject.org/
Or is a bit… Big?
First thing that comes into my mind when you need a “trello-like” self-hosted solution: Kanboard.
When installing on NethServer you probably want to use a Virtualhost.
We have Phabricator for nethserver. I have been using more than a year so far and it works great.
It has many other functionalities but you can disable all of them and use only the project and task management feature.
https://wiki.nethserver.org/doku.php?id=ht_phabricator
Upping this old thread for asking…
Anything new? I’d like to use a Neth official package or a NethForge one, if possible.
@pike it depends on what level of project management you are walking on. or require.
I and my team have been helping make contributions to the nextcloud deck, and i must say, at this juncture, it feels like a very good contender
So now options should be:
- Nextcloud + Deck (official package + addon from NextCloud)
- Phabricator (manual install)
Am i wrong?
Something is missing?
yes, thats is correct.
though with Phabricator, i think a much better install instruction needs to be made, as most omponents and requisites have been updated, from php version to db versions etc, so the current wiki might give you some challenges here and there, unless you can manage to overcome them.
That’s why it’s on the wiki–feel free to update as needed.
