I see links on the web for Nethvoice based on freepbx/asterisk. Is there any timetable or code ready for testing? Thanks
Not yet. I’d like to release FreePBX, Asterisk and configuration packages soon, but at the moment I’ve some trouble building a FreePBX package and a lack of time.
Is there someone who would like to help with that?
Currently NethVoice is just an Enterprise module, in case you’re interested ping Enterprise guys here:
http://www.nethserver.org/community-or-enterprise/
I’ve created an issue to keep track of this development.
http://dev.nethserver.org/issues/3130
I’ve also added Asterisk 11 rpms to nethserver-testing repository
first : some missing dependencies
Error: Package: asterisk-dahdi-11.16.0-2.el6.x86_64 (nethserver-testing)
Requires: libtonezone
Error: Package: asterisk-11.16.0-2.el6.x86_64 (nethserver-testing)
Requires: libsrtp
Requires: libss7
Error: Package: asterisk-calendar-11.16.0-2.el6.x86_64 (nethserver-testing)
Requires: libiksemel.so.3()(64bit)
Error: Package: asterisk-fax-11.16.0-2.el6.x86_64 (nethserver-testing)
Requires: libspandsp.so.2()(64bit)
Requires: libpri
Requires: dahdi-tools >= 2.0.0
Rquires: portaudio
but resolving all following dependencies is creazy… you find here the packages
http://packages.digium.com/centos/6/current/x86_64/RPMS/
http://packages.asterisk.org/centos/6/current/x86_64/RPMS/
portaudio is in epel
and lisbspandsp is here RPM Search libspandsp.so.2
you need also php-pear and after you have to do
pear channel-update
pear.php.netpear install db-1.7.14
and php-pear-DB in epel
but btw you have in http://$ip/admin a list of the directory instead of freepbx home page
some problem probably with the apache config and other permission in the fs
Set ownership permissions.
chown asterisk. /var/run/asterisk
chown -R asterisk. /etc/asterisk
chown -R asterisk. /var/{lib,log,spool}/asterisk
chown -R asterisk. /usr/lib/asterisk
chown -R asterisk. /usr/lib64/asterisk
mkdir /var/www/html
chown -R asterisk. /var/www/
A few small modifications to Apache.
sed -i ‘s/(^upload_max_filesize = )./\120M/’ /etc/php.ini
cp /etc/httpd/conf/httpd.conf /etc/httpd/conf/httpd.conf_orig
sed -i 's/^(User|Group)./\1 asterisk/’ /etc/httpd/conf/httpd.conf
service httpd restart
