NethServer Version: 7.9.2009
Module: Nextcloud 22.2.0
Hello friends,
I have updated the Onlyoffice app in my NC and now I cannot create new documents. Every attempt ends with this error message:
The “documentType” parameter for the config object is invalid. Please correct it.
What happened and how do I get this corrected?
Regards…
Uwe
mrmarkuz
(Markus Neuberger)
November 3, 2021, 1:30am
3
I couldn’t reproduce the issue. I still can create documents after updating the Onlyoffice app in Nextcloud 22.2.0.
Which onlyoffice version do you use?
[root@server2 ~]# rpm -q onlyoffice-documentserver
onlyoffice-documentserver-6.4.2-6.x86_64
Did you try to reapply the onlyoffice config?
signal-event nethserver-onlyoffice-update
Does it work to save the configuration in the Nextcloud Onlyoffice settings by pressing the “Save” button?
The case is closed. I forgot to update the onlyoffice server itself to the latest version 6.4.2.6 before updating the app. Now everything is running again.
Thanks and greetings…
pike
(Michael Kicks)
November 3, 2021, 4:01pm
5
Mark your post as solution. Who knows, tomorrow someone will look up for the same error
Hello friends,
I have to activate this old thread again. Today I updated Nextcloud and Onlyoffice to the latest version of each. Nextcloud via Nethserver Update and Onlyoffice to 7.2.2 as @mrmarkuz described in his tutorial. With the result that Now Onlyoffice no longer works and gives me these error messages:
Fehler beim Anschließen (cURL error 7: Failed connect to server.xxx.com:8082 ; Connection refused (see libcurl - Error Codes ) for https://server.xxx.com:8082/healthcheck )
and
Unfortunately, the problem cannot be solved with the usual means.
Regards…
Uwe
mrmarkuz
(Markus Neuberger)
September 25, 2022, 8:19pm
7
I could reproduce the issue, I need to check, there were some changes in the nginx config files.
As a workaround you could go back to the previous version 7.1.1:
yum downgrade https://github.com/ONLYOFFICE/DocumentServer/releases/download/v7.1.1/onlyoffice-documentserver.x86_64.rpm
Hi@mrmarkuz,
The downgrade went through cleanly. Nginx also starts again. But Onlyoffice still does not want to work. Now it gives this error when I press the Save button in the Onlyoffice configuration in the NC instance.
Fehler beim Anschließen (Im Dokumentenservice ist ein Fehler aufgetreten: Unknown error) (version 7.1.1.23)
Regrads…
Uwe
mrmarkuz
(Markus Neuberger)
September 26, 2022, 5:21pm
9
Did you already upgrade the Nextcloud Onlyoffice app to the latest version 7.5.4?
transocean:
Unknown error
Please check the logfiles /var/lib/nethserver/nextcloud/nextcloud.log and /var/log/onlyoffice/documentserver/docservice/*
mrmarkuz
(Markus Neuberger)
September 26, 2022, 6:40pm
11
Let’s try the healthcheck manually:
curl -k https://localhost:8082/healthcheck
and
curl -k https://teamserver.yourdomain.com:8082/healthcheck
should give back “true”.
I can’t reach your OnlyOffice site, maybe a firewall issue?
We can clos the case agaim. After a full dete and reinstall of Onlyoffice it works now. But i am on the version 7.1.1 and not on the latest.
