Yes, file exists. Here is the output:
<?php
* @copyright Copyright (c) 2016, ownCloud, Inc.
* @author Bart Visscher <bartv@thisnet.nl>
* @author Joas Schilling <coding@schilljs.com>
* @author Lukas Reschke <lukas@statuscode.ch>
* @author Morris Jobke <hey@morrisjobke.de>
* @author Philipp Schaffrath <github@philipp.schaffrath.email>
* @author Robin Appelman <robin@icewind.nl>
* @author Robin McCorkell <robin@mccorkell.me.uk>
* @author Roeland Jago Douma <roeland@famdouma.nl>
* @author Thomas Müller <thomas.mueller@tmit.eu>
* @license AGPL-3.0
* This code is free software: you can redistribute it and/or modify
* it under the terms of the GNU Affero General Public License, version 3,
* as published by the Free Software Foundation.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU Affero General Public License for more details.
* You should have received a copy of the GNU Affero General Public License, version 3,
* along with this program. If not, see <http://www.gnu.org/licenses/>
namespace OC\DB;
use Doctrine\DBAL\DBALException;
use Doctrine\DBAL\Driver;
use Doctrine\DBAL\Configuration;
use Doctrine\DBAL\Cache\QueryCacheProfile;
use Doctrine\Common\EventManager;
use Doctrine\DBAL\Platforms\MySqlPlatform;
use Doctrine\DBAL\Exception\ConstraintViolationException;
use Doctrine\DBAL\Schema\Schema;
use OC\DB\QueryBuilder\QueryBuilder;
use OCP\DB\QueryBuilder\IQueryBuilder;
use OCP\IDBConnection;
use OCP\PreConditionNotMetException;
class Connection extends ReconnectWrapper implements IDBConnection {
* @var string $tablePrefix
protected $tablePrefix;
* @var \OC\DB\Adapter $adapter
protected $adapter;
protected $lockedTable = null;
public function connect() {
try {
return parent::connect();
} catch (DBALException $e) {
// throw a new exception to prevent leaking info from the stacktrace
throw new DBALException('Failed to connect to the database: ' . $e->getMessage(), $e->getCode());
* Returns a QueryBuilder for the connection.
* @return \OCP\DB\QueryBuilder\IQueryBuilder
public function getQueryBuilder() {
return new QueryBuilder(
$this,
\OC::$server->getSystemConfig(),
\OC::$server->getLogger()
* Gets the QueryBuilder for the connection.
* @return \Doctrine\DBAL\Query\QueryBuilder
* @deprecated please use $this->getQueryBuilder() instead
public function createQueryBuilder() {
$backtrace = $this->getCallerBacktrace();
\OC::$server->getLogger()->debug('Doctrine QueryBuilder retrieved in {backtrace}', ['app' => 'core', 'backtrace' => $backtrace]);
return parent::createQueryBuilder();
* Gets the ExpressionBuilder for the connection.
* @return \Doctrine\DBAL\Query\Expression\ExpressionBuilder
* @deprecated please use $this->getQueryBuilder()->expr() instead
public function getExpressionBuilder() {
\OC::$server->getLogger()->debug('Doctrine ExpressionBuilder retrieved in {backtrace}', ['app' => 'core', 'backtrace' => $backtrace]);
return parent::getExpressionBuilder();
* Get the file and line that called the method where `getCallerBacktrace()` was used
* @return string
protected function getCallerBacktrace() {
$traces = debug_backtrace(DEBUG_BACKTRACE_IGNORE_ARGS, 2);
// 0 is the method where we use `getCallerBacktrace`
// 1 is the target method which uses the method we want to log
if (isset($traces[1])) {
return $traces[1]['file'] . ':' . $traces[1]['line'];
return '';
* @return string
public function getPrefix() {
return $this->tablePrefix;
* Initializes a new instance of the Connection class.
* @param array $params The connection parameters.
* @param \Doctrine\DBAL\Driver $driver
* @param \Doctrine\DBAL\Configuration $config
* @param \Doctrine\Common\EventManager $eventManager
* @throws \Exception
public function __construct(array $params, Driver $driver, Configuration $config = null,
EventManager $eventManager = null)
if (!isset($params['adapter'])) {
throw new \Exception('adapter not set');
if (!isset($params['tablePrefix'])) {
throw new \Exception('tablePrefix not set');
parent::__construct($params, $driver, $config, $eventManager);
$this->adapter = new $params['adapter']($this);
$this->tablePrefix = $params['tablePrefix'];
parent::setTransactionIsolation(parent::TRANSACTION_READ_COMMITTED);
* Prepares an SQL statement.
* @param string $statement The SQL statement to prepare.
* @param int $limit
* @param int $offset
* @return \Doctrine\DBAL\Driver\Statement The prepared statement.
public function prepare( $statement, $limit=null, $offset=null ) {
if ($limit === -1) {
$limit = null;
if (!is_null($limit)) {
$platform = $this->getDatabasePlatform();
$statement = $platform->modifyLimitQuery($statement, $limit, $offset);
$statement = $this->replaceTablePrefix($statement);
$statement = $this->adapter->fixupStatement($statement);
return parent::prepare($statement);
* Executes an, optionally parametrized, SQL query.
* If the query is parametrized, a prepared statement is used.
* If an SQLLogger is configured, the execution is logged.
* @param string $query The SQL query to execute.
* @param array $params The parameters to bind to the query, if any.
* @param array $types The types the previous parameters are in.
* @param \Doctrine\DBAL\Cache\QueryCacheProfile|null $qcp The query cache profile, optional.
* @return \Doctrine\DBAL\Driver\Statement The executed statement.
* @throws \Doctrine\DBAL\DBALException
public function executeQuery($query, array $params = array(), $types = array(), QueryCacheProfile $qcp = null)
$query = $this->replaceTablePrefix($query);
$query = $this->adapter->fixupStatement($query);
return parent::executeQuery($query, $params, $types, $qcp);
* Executes an SQL INSERT/UPDATE/DELETE query with the given parameters
* and returns the number of affected rows.
* This method supports PDO binding types as well as DBAL mapping types.
* @param string $query The SQL query.
* @param array $params The query parameters.
* @param array $types The parameter types.
* @return integer The number of affected rows.
public function executeUpdate($query, array $params = array(), array $types = array())
return parent::executeUpdate($query, $params, $types);
* Returns the ID of the last inserted row, or the last value from a sequence object,
* depending on the underlying driver.
* Note: This method may not return a meaningful or consistent result across different drivers,
* because the underlying database may not even support the notion of AUTO_INCREMENT/IDENTITY
* columns or sequences.
* @param string $seqName Name of the sequence object from which the ID should be returned.
* @return string A string representation of the last inserted ID.
public function lastInsertId($seqName = null) {
if ($seqName) {
$seqName = $this->replaceTablePrefix($seqName);
return $this->adapter->lastInsertId($seqName);
// internal use
public function realLastInsertId($seqName = null) {
return parent::lastInsertId($seqName);
* Insert a row if the matching row does not exists. To accomplish proper race condition avoidance
* it is needed that there is also a unique constraint on the values. Then this method will
* catch the exception and return 0.
* @param string $table The table name (will replace *PREFIX* with the actual prefix)
* @param array $input data that should be inserted into the table (column name => value)
* @param array|null $compare List of values that should be checked for "if not exists"
* If this is null or an empty array, all keys of $input will be compared
* Please note: text fields (clob) must not be used in the compare array
* @return int number of inserted rows
* @deprecated 15.0.0 - use unique index and "try { $db->insert() } catch (UniqueConstraintViolationException $e) {}" instead, because it is more reliable and does not have the risk for deadlocks - see https://github.com/nextcloud/server/pull/12371
public function insertIfNotExist($table, $input, array $compare = null) {
return $this->adapter->insertIfNotExist($table, $input, $compare);
public function insertIgnoreConflict(string $table, array $values) : int {
return $this->adapter->insertIgnoreConflict($table, $values);
private function getType($value) {
if (is_bool($value)) {
return IQueryBuilder::PARAM_BOOL;
} else if (is_int($value)) {
return IQueryBuilder::PARAM_INT;
} else {
return IQueryBuilder::PARAM_STR;
* Insert or update a row value
* @param array $keys (column name => value)
* @param array $values (column name => value)
* @param array $updatePreconditionValues ensure values match preconditions (column name => value)
* @return int number of new rows
* @throws PreConditionNotMetException
* @suppress SqlInjectionChecker
public function setValues($table, array $keys, array $values, array $updatePreconditionValues = []) {
try {
$insertQb = $this->getQueryBuilder();
$insertQb->insert($table)
->values(
array_map(function($value) use ($insertQb) {
return $insertQb->createNamedParameter($value, $this->getType($value));
}, array_merge($keys, $values))
return $insertQb->execute();
} catch (ConstraintViolationException $e) {
// value already exists, try update
$updateQb = $this->getQueryBuilder();
$updateQb->update($table);
foreach ($values as $name => $value) {
$updateQb->set($name, $updateQb->createNamedParameter($value, $this->getType($value)));
$where = $updateQb->expr()->andX();
$whereValues = array_merge($keys, $updatePreconditionValues);
foreach ($whereValues as $name => $value) {
$where->add($updateQb->expr()->eq(
$name,
$updateQb->createNamedParameter($value, $this->getType($value)),
$updateQb->where($where);
$affected = $updateQb->execute();
if ($affected === 0 && !empty($updatePreconditionValues)) {
throw new PreConditionNotMetException();
return 0;
* Create an exclusive read+write lock on a table
* @param string $tableName
* @throws \BadMethodCallException When trying to acquire a second lock
* @since 9.1.0
public function lockTable($tableName) {
if ($this->lockedTable !== null) {
throw new \BadMethodCallException('Can not lock a new table until the previous lock is released.');
$tableName = $this->tablePrefix . $tableName;
$this->lockedTable = $tableName;
$this->adapter->lockTable($tableName);
* Release a previous acquired lock again
* @since 9.1.0
public function unlockTable() {
$this->adapter->unlockTable();
$this->lockedTable = null;
* returns the error code and message as a string for logging
* works with DoctrineException
* @return string
public function getError() {
$msg = $this->errorCode() . ': ';
$errorInfo = $this->errorInfo();
if (is_array($errorInfo)) {
$msg .= 'SQLSTATE = '.$errorInfo[0] . ', ';
$msg .= 'Driver Code = '.$errorInfo[1] . ', ';
$msg .= 'Driver Message = '.$errorInfo[2];
return $msg;
* Drop a table from the database if it exists
* @param string $table table name without the prefix
public function dropTable($table) {
$table = $this->tablePrefix . trim($table);
$schema = $this->getSchemaManager();
if($schema->tablesExist(array($table))) {
$schema->dropTable($table);
* Check if a table exists
* @return bool
public function tableExists($table){
return $schema->tablesExist(array($table));
// internal use
* @return string
protected function replaceTablePrefix($statement) {
return str_replace( '*PREFIX*', $this->tablePrefix, $statement );
* Check if a transaction is active
* @return bool
* @since 8.2.0
public function inTransaction() {
return $this->getTransactionNestingLevel() > 0;
* Escape a parameter to be used in a LIKE query
* @param string $param
* @return string
public function escapeLikeParameter($param) {
return addcslashes($param, '\\_%');
* Check whether or not the current database support 4byte wide unicode
* @return bool
* @since 11.0.0
public function supports4ByteText() {
if (!$this->getDatabasePlatform() instanceof MySqlPlatform) {
return true;
return $this->getParams()['charset'] === 'utf8mb4';
* Create the schema of the connected database
* @return Schema
public function createSchema() {
$schemaManager = new MDB2SchemaManager($this);
$migrator = $schemaManager->getMigrator();
return $migrator->createSchema();
* Migrate the database to the given schema
* @param Schema $toSchema
public function migrateToSchema(Schema $toSchema) {
$migrator->migrate($toSchema);
