gerald_FS
(Gerald)
December 15, 2018, 7:55am
1
Hello,
after the last routinely update on Dec. 14th to the
System version NethServer release 7.6.1810 (final)
Kernel 3.10.0-862.14.4.el7.x86_64
SOGo can no longer access the mailboxes of the user, as well as the reception and sending of mail is no longer possible.
Is there a solution to the problem?
greetings
Gerald
gerald_FS
(Gerald)
December 15, 2018, 9:23am
2
That would be the approach I have …
Here would be an excerpt from the mail log:
> Dec 15 09:11:22 openzwo dovecot: lmtp(7652): Connect from local Dec 15 09:11:22 openzwo dovecot: lmtp(7652, gerald.musch@nandlnet.de): Fatal: Plugin 'sieve_imapsieve' not found from directory /usr/lib64/dovecot/sieve Dec 15 09:11:23 openzwo postfix/lmtp[7651]: 8F1B253C: to=<gerald.musch@nandlnet.de>, relay=openzwo.nandlnet.de[/var/run/dovecot/lmtp], delay=522, delays=522/0.06/0.08/0.12, dsn=4.4.2, status=deferred (lost connection with openzwo.nandlnet.de[/var/run/dovecot/lmtp] while sending end of data -- message may be sent more than once)
It seems that dovecot-pigeonhole is missing.
You could try to install it with yum dovecot-pigeonhole.
Here’s what I have:
[root@nethservice ~]# rpm -q dovecot-pigeonhole
dovecot-pigeonhole-2.2.36-3.el7.x86_64
gerald_FS
(Gerald)
December 15, 2018, 9:30am
4
I also have the same version:
[root@openzwo ~]# rpm -q dovecot-pigeonhole
dovecot-pigeonhole-2.2.10-8.el7.x86_64
[root@openzwo ~]#
I wanted to reinstall but then I get the following error message that it is not found.
[root@openzwo ~]# yum reinstall dovecot-pigeonhole*
Loaded plugins: auto-update-debuginfo, changelog, fastestmirror, nethserver_events
* ce-base: ftp.heanet.ie
* ce-extras: ftp.heanet.ie
* ce-updates: ftp.heanet.ie
* epel: mirror.imt-systems.com
* epel-debuginfo: mirror.imt-systems.com
* nethforge: server.liftingtrade.hu
* nethserver-updates: server.liftingtrade.hu
Resolving Dependencies
--> Running transaction check
---> Package dovecot-pigeonhole.x86_64 1:2.2.10-8.el7 will be reinstalled
Dependencies Resolved
Package Arch Version Repository Size
Reinstalling:
dovecot-pigeonhole x86_64 1:2.2.10-8.el7 ce-base 304 k
Transaction Summary
Reinstall 1 Package
Total download size: 304 k
Installed size: 1.1 M
Is this ok [y/d/N]: y
Downloading packages:
dovecot-pigeonhole-2.2.10-8.el FAILED
http://mirror.rackspace.com/CentOS/7.6.1810/os/x86_64/Packages/dovecot-pigeonhole-2.2.10-8.el7.x86_64.rpm: [Errno 14] HTTP Error 404 - Not Found ] 0.0 B/s | 0 B --:--:-- ETA
Trying other mirror.
To address this issue please refer to the below wiki article
https://wiki.centos.org/yum-errors
If above article doesn't help to resolve this issue please use https://bugs.centos.org/.
mark_nl
(Mark Verlinde)
December 15, 2018, 9:46am
5
maybe cleaning up the yum cache can help?
You may run:
yum clean all && yum makecache
and after this try do a full update:
yum update
gerald_FS
(Gerald)
December 15, 2018, 3:44pm
6
Hi, Thank You @mark_nl !
That was the problem.
Only why the installation routine always gets stuck, that was the problem for the second time.
greetings
Gerald
