Problems wit Onlyoffice Documentserver after Update to version 5.4.2
NethServer Version: Latest
Module: OnlyOffice Documentserver
Hi Friends,
i updated the ONLYOFFICE document server to version 5.4.2. Now the Nginx service no longer starts. I get this error message when I try to start the service from the cockpit:
dns.service_action_error
Der folgende Befehl ist gescheitert:
system-services/update
What must i do?
Regards
Uwe
Edit: After reboot the Nginx Service is running. Now httpd service is down and it is not possible to start them. But when i stop Nginx Service i casn start httpd by hand.
It seems nginx uses default http/https ports so it conflicts with httpd.
From which documentserver version did you update?
Does it help to reconfigure?
signal-event nethserver-onlyoffice-update
Do you see errors in the logfiles?
This is the solution. Sorry Markus, i am old and my eyes are not the best…
