Problems to install Nextcloud
NethServer Version: NS7
Module: Nextcloud
Hello friends,
after a long time i am back and want to install nextcloud in version 11. But there is a problem. After downloading via ssh and the first step of installation i received this error:
Transaction check error:
file /etc/httpd/conf.d/nextcloud.conf from install of nextcloud-11.0.2-1.4.ns7.noarch conflicts with file from package nextcloud-httpd-10.0.4-2.el7.noarch
What must i do to solve this problem?
Regards and happy easter…
Uwe
You have some nextcloud packages from epel repo that were conflicting with the version built for nethserver.
rpm -qa *nextcloud*
Did you have nextcloud installed since long time and updated recently?
Where does your nextcloud data lives? Is it in /var/lib/nethserver/nextcloud or somewhere else?
We have removed NextCloud for the time being as we had applied the latest in the testing repo but then had no end of DNS issues that only stopped when it was removed.
Need to build a test server to get better diagnostics on the issue.
after killing and reinstall the OS Nextcloud works now.
Regards
Uwe
