Problems on Nethserver stable repro on trail abonnement
NethServer Version: 7.5
Module: abonnement
yesterday I tried to install some software from Dans repro. Additionally, I subscribed a 30 days trial account.
For some reasons, the official repro mirror does not work:
https://m1.nethserver.com/stable/7.5.1804/base/x86_64/repodata/repomd.xml: [Errno 14] HTTPS Error 403 - Forbidden Trying other mirror.
The software management suggest to update yum cache, however this does not work either. I tried to remove trail abonnement on the management interface, but on my nethserver installation, the abonnement seems just to have lost its connection. Howe can I remove trail abonnement on my server?
How can I resolve the cache issue?
TIA
Thorsten
Advanced beginners mistake … I will consult / try out the manual. Sorry.
I will report, if it worked :slight_smile:
The same old rule applies: Why ask if you can read … or was it vice versa …:innocent:
Can you share how did you solved it?
Two options from manual:
Activating a subscription will enable the stable YUM repositories, but will disable any other repositories you may have added. You can re-enable any other repositories by creating a “template-custom” for /etc/nethserver/eorepo.conf.
or in my case I removed the subscription get access to the regular repros.
config setprop subscription Secret '' SystemId ''
signal-event software-repos-save
Ah, OK, I mixed up things, I did recall you wanted to remove the subscription (as said on first post). Thanks.
