NethServer Version: 7.9.2009
Module: hostname
This is a fairly new install. I will be using nethserver for file exchange with customers, via the Nextcloud app. Initially I had slapd and sssd installed, enabled, and running, so I removed the few users I had created and then I removed LDAP as the provider, thinking then I would be allowed to change my FQDN. However, in both server manager and cockpit, I get the same error saying Validation failed: Must contain at least two dots, like 'myhost.example.com'
, when I attempt to use the name rennco.cloud, which is a registered domain. I’m guessing I need to use a subdomain/cname, to look more like server.rennco.cloud, in order for the change to take effect? Is that a safe assumption?
