When I make a scheduled appointment in the calendar, I get the error message as seen in the picture. The date can be seen in all views in the calendar.
Maybe someone has a solution to the problem.
Merry Christmas and Thanks …
Uwe
Edit:
Sending a mail with WebTop does not work. I can write the mail, but not send. When I click the send button, this error message appears:
Here is the error message from logviewer:
“Dec 26 12:23:43 webmail postfix/smtpd[2003]: warning: connect to proxy filter 127.0.0.1:10024: Connection refused
Dec 26 12:23:43 webmail postfix/smtpd[2003]: proxy-reject: END-OF-MESSAGE: 451 4.3.0 Error: queue file write error; from=x.yyyy@mydomain.de to=x.yyzz@hisdomain.com proto=ESMTP helo=<www.sonicle.com>
Dec 26 12:23:43 webmail postfix/smtpd[2003]: disconnect from localhost[127.0.0.1]”
Yes the mail problem is thrown by the smtp server for some external reasons to webtop.
About the scheduler problem, there is a new postgres java library released with NS7 introducing the problem. We’re looking for a fix to work both on newer and older library versions.
