jordy
(Giordano)
1
hi, i have a big problem!
my netserver which has been out of order for months is not working:
- I no longer see users
- backup and restore configuration does not work
- the software center does not see any software or updates
I tried the configuration restore but it always comes out error:
The following command failed:
system-backup / execute
m.traeumner
(Michael Träumner)
3
You could try to update at the command line.
yum clean all
yum update
pike
(Michael Kicks)
4
@giordano most of the community is not italian, therefore messages in english will help to understand better issues and outputs from commands.
I’m sorry for the issues you’re encountering, but big question is: what do you mean for “out of order”?
ssabbath
(Walter Ferry Dissmann)
5
Have you tried simply start them manually and check the error?
systemctl start nsdc
systemctl start shorewall
what are the errors?
dnutan
(Marc)
6
Check for errors on the status of the related services (nsdc, sssd, nss*, …) or try to start them.
To get more details about why it fails, check the logs (probably /var/log/messages)
Which NethServer version? If it is too old maybe the repos it points to are no longer available (or they are archived).
cat /etc/nethserver-release
jordy
(Giordano)
7
sorry, I wrote wrong, I meant that it has been working for many months
jordy
(Giordano)
8
i solved it, i update manually and now it works.
Could you please mark the topic as solved.
