First of all, thanks for your effort in helping me out!
Still no luck iβm afraid. The compete output of the commands is in a file because of the size (seems too large to include in a forum message). How can i get it to you? There is a lot of activity going on after issuing the S30nethserver-dc-upgrade command. I did a reboot after the dc-upgrade to be sure but that didnβt help either.
For completeness Iβve added the logoutput after adding a user in Nethserver, same problems concerning the missing nsdc-run.sock and the user adding fails.
Sep 7 14:38:52 server1 esmith::event[7930]: Event: user-create cursus Cursus /usr/libexec/openssh/sftp-server
Sep 7 14:38:52 server1 esmith::event[7930]: Traceback (most recent call last):
Sep 7 14:38:52 server1 esmith::event[7930]: File "/bin/nsdc-run", line 38, in <module>
Sep 7 14:38:52 server1 esmith::event[7930]: so.connect('/var/lib/machines/nsdc/var/lib/misc/nsdc-run.sock')
Sep 7 14:38:52 server1 esmith::event[7930]: File "/usr/lib64/python2.7/socket.py", line 224, in meth
Sep 7 14:38:52 server1 esmith::event[7930]: return getattr(self._sock,name)(*args)
Sep 7 14:38:52 server1 esmith::event[7930]: socket.error: [Errno 2] No such file or directory
Sep 7 14:38:52 server1 esmith::event[7930]: [ERROR] User cursus creation failed
Sep 7 14:38:52 server1 esmith::event[7930]: Action: /etc/e-smith/events/user-create/S40nethserver-dc-user-create FAILED: 1 [0.143501]
Sep 7 14:38:53 server1 esmith::event[7930]: Traceback (most recent call last):
Sep 7 14:38:53 server1 esmith::event[7930]: File "/bin/nsdc-run", line 38, in <module>
Sep 7 14:38:53 server1 esmith::event[7930]: so.connect('/var/lib/machines/nsdc/var/lib/misc/nsdc-run.sock')
Sep 7 14:38:53 server1 esmith::event[7930]: File "/usr/lib64/python2.7/socket.py", line 224, in meth
Sep 7 14:38:53 server1 esmith::event[7930]: return getattr(self._sock,name)(*args)
Sep 7 14:38:53 server1 esmith::event[7930]: socket.error: [Errno 2] No such file or directory
Sep 7 14:38:53 server1 esmith::event[7930]: [ERROR] failed to modify UPN suffixes
Sep 7 14:38:53 server1 esmith::event[7930]: Action: /etc/e-smith/events/user-create/S50nethserver-dc-sync-upn FAILED: 1 [0.323891]
Sep 7 14:38:53 server1 esmith::event[7930]: [NOTICE] clearing sssd cache for user cursus@pa3hfj.nl
Sep 7 14:38:53 server1 esmith::event[7930]: No cache object matched the specified search
Sep 7 14:38:53 server1 esmith::event[7930]: Action: /etc/e-smith/events/user-create/S90nethserver-sssd-clear-cache SUCCESS [0.055937]
Sep 7 14:38:53 server1 esmith::event[7930]: Event: user-create FAILED
Sep 7 14:38:53 server1 esmith::event[7948]: Event: password-policy-update cursus no
Sep 7 14:38:53 server1 esmith::event[7948]: [NOTICE] clearing sssd cache for user cursus@pa3hfj.nl
Sep 7 14:38:53 server1 esmith::event[7948]: No cache object matched the specified search
Sep 7 14:38:53 server1 esmith::event[7948]: Action: /etc/e-smith/events/password-policy-update/S10nethserver-sssd-clear-cache SUCCESS [0.019247]
Sep 7 14:38:53 server1 esmith::event[7948]: Traceback (most recent call last):
Sep 7 14:38:53 server1 esmith::event[7948]: File "/bin/nsdc-run", line 38, in <module>
Sep 7 14:38:53 server1 esmith::event[7948]: so.connect('/var/lib/machines/nsdc/var/lib/misc/nsdc-run.sock')
Sep 7 14:38:53 server1 esmith::event[7948]: File "/usr/lib64/python2.7/socket.py", line 224, in meth
Sep 7 14:38:53 server1 esmith::event[7948]: return getattr(self._sock,name)(*args)
Sep 7 14:38:53 server1 esmith::event[7948]: socket.error: [Errno 2] No such file or directory
Sep 7 14:38:53 server1 esmith::event[7948]: [ERROR] Faild to set expiry on user cursus
Sep 7 14:38:53 server1 esmith::event[7948]: Action: /etc/e-smith/events/password-policy-update/S30nethserver-dc-password-policy FAILED: 1 [0.141984]
Sep 7 14:38:53 server1 esmith::event[7948]: Event: password-policy-update FAILED
Sep 7 14:38:53 server1 esmith::event[7957]: Event: password-modify cursus@pa3hfj.nl /tmp/ng-EHbzx6
Sep 7 14:38:53 server1 esmith::event[7957]: Action: /etc/e-smith/events/password-modify/S25password-set SUCCESS [0.003236]
Sep 7 14:38:53 server1 esmith::event[7957]: Traceback (most recent call last):
Sep 7 14:38:53 server1 esmith::event[7957]: File "/bin/nsdc-run", line 38, in <module>
Sep 7 14:38:53 server1 esmith::event[7957]: so.connect('/var/lib/machines/nsdc/var/lib/misc/nsdc-run.sock')
Sep 7 14:38:53 server1 esmith::event[7957]: File "/usr/lib64/python2.7/socket.py", line 224, in meth
Sep 7 14:38:53 server1 esmith::event[7957]: return getattr(self._sock,name)(*args)
Sep 7 14:38:53 server1 esmith::event[7957]: socket.error: [Errno 2] No such file or directory
Sep 7 14:38:53 server1 esmith::event[7957]: Action: /etc/e-smith/events/password-modify/S30nethserver-dc-password-set FAILED: 1 [0.03395]
Sep 7 14:38:53 server1 esmith::event[7957]: Action: /etc/e-smith/events/password-modify/S40nethserver-dc-user-unlock FAILED: 1 [0.030531]
Sep 7 14:38:54 server1 esmith::event[7957]: Action: /etc/e-smith/events/password-modify/S90password-cleanup SUCCESS [0.627883]
Sep 7 14:38:54 server1 esmith::event[7957]: Event: password-modify FAILED
