I’m using NethServer 6.5 in production on company i’m working on.
NS is joined to AD 2008 r2 (nobody’s perfect…)
I’ve installed Groupware solution with nethserver-sogo packages and everything is working well.
Sometimes, i have something who is blocking dovecot (BIG problem because crash of sogo and thunderbird), and the logs are saying :
Mar 18 16:06:00 dmz1 dovecot: auth-worker(53032): Error: LDAP: binding failed (dn (none)): Local error, SASL(-1): generic failure: GSSAPI Error: Unspecified GSS failure. Minor code may provide more information (Requested effective lifetime is negative or too short)
I’ve tried signal-event nethserver-mail-* but nothing new.
One other way is date, in my case, Nethserver is virtualized with Hyper-V witch is automaticly update time from hyperviser… AD have 5 minutes more than NS…
Iv’e ntp those 2 machines and i’m seeking for bug reproduce…
To ge around the bug, i need to reboot server.
I can see there is a problem with kerberos ticket wich is seems to be expired like logs of dovecot say :
indent preformatted text by 4 spacesMar 25 16:42:55 dmz1 dovecot: auth: Error: LDAP: binding failed (dn (none)): Local error, SASL(-1): generic failure: GSSAPI Error: Unspecified GSS failure. Minor code may provide more information (Ticket expired)
There is a socket file for kerberos in /tmp…
Just after rebooting, i can see this in dovecot log file :
Mar 25 16:45:58 dmz1 dovecot: master: Dovecot v2.1.16 starting up (core dumps disabled)
It confirm that krb5cc_xx file is created when the service is up :
-rw-------. 1 postfix root 3451 Mar 25 13:04 krb5cc_89
-rw-------. 1 dovecot root 3451 Mar 25 16:45 krb5cc_97
I need to see if a file is present when bug will be reproduced…If anyone have ideas…
This seems a different problem: now the ticket is completely expired. The /etc/cron.hourly/smbads_tgt should check it every hour end refresh it when it will expire soon. As a temporary workaround, maybe service dovecot restart is enough.
The AD machine has been down for a while?
Could you dig into /var/log/messages and /var/log/maillog?
