If I want to insert a bypass for example sites without proxy the name can’t begin with a capital, but the error message says that only letters after the first have to be small.
Sea the picture
In English is not so clear too:
first letter, than only lower letters, numbers and symbols like “-” and “_”
How can we change it properly?
if I read this sentence I think the first letter could be capital. But if give a name like “Test” it dosn’t work, but with “test” it’s no problem.
Here’s my test with the english userinterface:
Hi all,
what do you think about this message (in english):
“first character must be a lower letter, than only lower letters, numbers and symbols like “-” and “_”.No capital letters allowed.”
I think that probably it’s a bit too redundant but effective
I think this message says at first a letter not a number or symbol, after that only lower letters. That means for me the first letter could be a capital.
It looks clear to me! It has to be a letter and it must be lower.
I think the problem is the word than, it’s a synonym for as, but for me it dosn’t make sense in this sentence. Due to this fact and the german translation I think it should be then with “e”. But this means “after that”, and so I thought the first letter could be acapital.
What do you think about this error message:
At first a letter, then letters, numbers and symbols like “-” and “". All letters have to be small.
In german it is:
Als erstes ein Buchstabe, dann Buchstaben, Zahlen und Symbole wie “-” und "”. Es dürfen nur Kleinbuchstaben verwendet werden.
This is only a mistranlation not a bug imo. If your luanguage is set to german the message is not clear.
If you translate the german text to english it says:
First a charater, than only lower characters, numbers and symbols like.....
Maybe @hunv from german translation team can correct this?
If someone tells my how to search for the translation in Transifex, I can do that. But at the moment I simply don’t find it
I think it’s this one: https://www.transifex.com/nethserver/nethserver/translate/#it/Nethgui/45198665
OK, changed it.
But the original english error message says the same, see my second post. So I think it has to be corrected in english too.
What if the sentence beginning with “No capital letters allowed.” ?
I think this is a good idea.
