Problem with Mattermost when using same FQDN the host
NethServer Version: 7.6.1810 (final)
Module: nethserver-mattermost-1.2.3-1
When you set up Mattermost FQDN to be the same as the host FQDN, is not possible to reach this service, bear in mind that Mattermost is the only module installed on this Nethserver instance.
How can I solve this ?
If I recall correctly you must use a subdomain like mattermost.domain.com, I think it is not possible like this to use the same vhost
if really really you want it, it is an apache reverse proxy to the mattermost tcp port, so I think you could do it yourself
Change hostname of the server, and use the “wanna be” hostname for mattermost.
