Mat.78
(Matteo)
1
Hello,
I try to setup an ftp server to scan documents directly to the scan shared folder.
I followed the instructions here to enable system user access to the ftp server and now I can no longer connect to the FTP server.
What can I do to restore the ftp server?
Thank you
Matteo
NethServer Version: 7.7.1908
Module: web-server
pike
(Michael Kicks)
2
Which kind of users did you enabled FTP access for? Virtual or system?
Could you please elaborate a bit more the user infrastructure of your server?
Mat.78
(Matteo)
3
I run the code:
config setprop vsftpd UserType system
then I try to assign the right to login to the scan user with this code:
db accounts setprop scan FTPAccess enabled
db accounts setprop scan Shell /bin/bash
signal-event user-modify scan
I apply this configuration:
signal-event nethserver-vsftpd-save
When I try to connect to the server I receive an error (authentication failed - Connection failed - Permission Denied).
I use “active directory” domain and I set up a scan directory to store my scanned document.
If I use virtual user I can login to the server.
