I have a problem with the navigation… When I open a page (i think is a problem only with google and its services like analytics & co.) it remains in loading state and says “Creazione di una connessione protetta in corso” (Creating a secure connection in progress)…
I have insert google domains in whitelist and also in “Domain without proxy” but it’s the same.
I opened only 80 and 443 ports… google use other ports?
If it is a log with time just take the time slice when the error occured. In other case reproduce the error and just take the last x lines of the log immediately. You can do it in the web UI in “Administration/Log Viewer” or via command line:
tail -n 20 /var/log/squid/access.log
for getting the last 20 lines of /var/log/squid/access.log
in fact I’m also having problems with google and the ssl transparent proxy in the last few days (never before). I’m forced to manually set up the proxy in Android connections
In fact, the problem is in particular google but on other site https navigation is slowly than http navigation.
Someone can check this?
If someone of developers found this, can correct the bug?
Thanks… My network is composed by 250 computers, but on http and on google (that is excluded by proxy) it works very well and on https it is slow…
