Hello Friends,
i have now carried out one last test. I have set up two new VM’s with Debian 12 bookworm and installed NS 8 on them. 1x Leader with only Samba AD on it and 1x Worker with Mail, Webtop, Nextcloud, Collabora and Mattermost on it. The AD on the Leader node is stable. On the Worker node, only the mail server and Mattermost work satisfactorily. Nextcloud runs much slower than under NS 8 in conjunction with Rocky 9.3, also Collabora. Webtop can be installed, but the login does not work. Both nodes ran with four processor cores and 20 GB RAM each under Proxmox on an ODROID H3+. It may be that the difficulties have something to do with the hardware, which is designed to be somewhat economical. At least as far as the processor is concerned. However, the question remains as to why this works without problems under Rocky 9.3 and also uses the RAM more sparingly. For my part, I will say goodbye to NS8 in conjunction with Debian for the time being and use Rocky Linux as the basic framework for NS8 in future.
Regards…
Uwe
